Quick carpet question
Car: 1982 Trans Am
Engine: LG4
Transmission: 200c
The carpet on my 82 is sagging right where my pedals are, as in whatever was keeping the carpet in place has been broken and there is nothing holding it in place. Does anybody know if there is a way to get my carpet situated where it should be? or is it a matter of the glue or whatever used to hold it in place has worn out. Thanks in advance!
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Quick carpet question
If it's in the flat area in front of the pedals, it was glued with a adhesive sheet.I've used spray adhesive to re-apply it.
If you mean the portion above/behind the pedals, I think nothing held it inplace but, itself.
Car: 1982 Trans Am
Engine: LG4
Transmission: 200c
It is the portion behind the pedals, any recommendations on how to fix this? Do you think the spray adhesive would do the job? Or does it require a replacement.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Only thing I can think of is spray adhesive or maybe velcro.Either is probably not a permanent solution.
goalieforlife
Sep 20, 2016 05:29 PM
formula00ra
Apr 20, 2016 04:55 AM
