Keeping t-top weatherstripping in good shape
Old Apr 20, 2016 | 09:48 PM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
What do u guys use to keep the weatherstripping from cracking.. i heard WD-40.. anything else?
Old Apr 20, 2016 | 10:21 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Keeping t-top weatherstripping in good shape
Keep petroleum products away from weatherstrip.
Here's what GM specifies:
Part Number 1052863 is obsolete, I'm sure.
I use this: http://agscompany.com/product/sil-gl...ant-tube-4-oz/
Old Apr 21, 2016 | 12:05 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Leave the ttops off while in the garage
Old Apr 22, 2016 | 09:48 PM
Engine: V8 305
you guys don't spray them with anything? u just put silicone on them? anybody else do this?
Old Apr 22, 2016 | 10:51 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I used silicone grease since you can usually find a tube of it for pretty cheap and it lasts a long while. When you apply it you want to use as little as possible and massage it all over the stripping. If you apply too much it will give you those long stringy pieces when pulling off the top and collect dust and gunk much easier. When you reapply it you'll want to try and clean off the old stuff since dirt/dust will cling to it no matter what you do. I don't know if the regular dressings for hoses and tires is technically OK for it or not because you can get silicone based dressings but I have used them.
Old Apr 23, 2016 | 04:42 PM
mjoekingz28's Avatar
Car: 2006 Chevrolet Cobalt
Engine: 2.2 DOHC Ecotec
Transmission: 4spd auto
I feel silicone/dielectric/tune-up/bulb grease is great if they are new. Chances are most of us don't get to tend to something until it is well past optimum time.
So,
First I would clean them (and be thorough since there are folds, nooks and crannies in a weatherstrip) and be gentle in case they are soft and/or degraded. Mix your car wash soap with water as you would when washing your car- into a spray bottle. Use this with a soft cloth to clean. Then you can dry, air dry by leaving the door open, or get a pad with an armor all product and wipe down the weatherstrip. THEN I think the rubber will better accept the grease!
Old Apr 28, 2016 | 01:39 AM
Engine: V8 305
Old Apr 28, 2016 | 01:41 AM
Your welcome.
When I first tried, I used red #2 chassis grease. I soon learned I was close, but off. I cleaned it off and kept trying.....back in 2007.
Old Apr 28, 2016 | 12:29 PM
DonW's Avatar
Car: 1983 Z28
Engine: Carbed 305
Ive always just used Liquid Wrench Silicone Spray. Mostly because I always have some of that around my shop and its easy to lay hands on. Ive used it for years with no adverse effects. Keeps the rubber soft and doesn't gum up or leave a ring around the glass on your tops. I just spray a little on a rag and wipe the rubber down good and let it dry before putting the tops back on. It also keeps the tops from squeaking. Of course being silicone it will have excellent UV protection for when the tops are out.
Old Apr 28, 2016 | 03:07 PM
Just a FYI, some silicone sprays can be bad for plastic. Some state it on the can. Some rubber is plasticized- meaning it is an 'alloy' of plastic and rubber.
Old Apr 28, 2016 | 08:45 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I'm not seeing a "care" section on the Metro website, or on Steele's.
Metro does say this as an assembly aid.
"Apply a water-based lubricant / protectant such as Armorall, or a silicone based furniture polish like Lemon Pledge, to METRO parts where noted in the instructions."
http://metrommp.com/pages/Technical/...ationTips.html
First time I've heard the Lemon Pledge recommendation.
Wait...found it.
"How do I maintain rubber?
To give your rubber that clean new, jet black look, start by cleaning it with mild soap and water. Follow with a rubber & vinyl protectant or even a silicone-based furniture polish. Do not spray protectants directly on the rubber. Rather, apply it to a damp rag then wipe it on.
Some rubber will naturally bleed paraffin, which will look like hardened candle wax. Use a solvent to carefully remove any visible paraffin.
Rubber's enemies
Rubber contains plasticizers that eventually "evaporate" from rubber, leaving it hardened and cracked. This is a naturally occurring process, but heat, sunlight, smog, chemicals and gasoline/oil can shorten the life of rubber parts."
http://metrommp.com/pages/Technical/...ng_rubber.html
Old Apr 29, 2016 | 05:33 PM
Engine: V8 305
thanks dave...apprecitated.
Old Apr 30, 2016 | 09:32 PM
MintWS6FORMULA's Avatar
From: Michigan [Bodacious Member with the Bodacious TA'TAs (Trans Ams)]
Car: 91 Formula - Authentic and REAL
Engine: 5.0 Liter
I always thought that was a good way to let the rodents in.
I guess you never saw "Caddyshack" either.
Old Apr 30, 2016 | 10:45 PM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
use nissan/infiniti krytox grease. designed specifically for the seals used in their convertibles.
Old May 1, 2016 | 03:12 PM
DynoDave43's Avatar
Interesting. A DuPont product.
Infiniti Technical Service Bulletin (TSB)...
www.infinitig37.com/TSB/ITB11-035a.pdf
A DuPont tech sheet on the Krytox line, but not this substance in particular.
www2.dupont.com/Lubricants/en_US/assets/downloads/krytox_gpl_106_206_216_226_K20067.pdf
And a place to buy it.
http://www.nissanpartsdeal.com/parts...306-5z000.html
SO akanitro, how do you prep for it, apply it, etc?
Old May 2, 2016 | 04:03 PM
Engine: V8 305
nice..
Old Aug 5, 2016 | 05:03 AM
z28cop's Avatar
Car: 1985 IROC-Z
Engine: L69
Axle/Gears: 373 Limited Slip
ive used Vasoline on the IROC, all the weatherstrips look great to this date 31 years later
Old Sep 20, 2016 | 01:45 AM
Engine: 5.0 Liter
Armour All and park out of the sun.
Old Sep 20, 2016 | 05:29 PM
Out-Cast's Avatar
Car: 1987 IROC z
Transmission: 700R
Axle/Gears: POSI 3:27s
Yup I was told Vaseline as well.
92fire-audio
Oct 11, 2001 02:48 PM
FiReBReTHa
Oct 10, 2001 09:52 AM
FiReBReTHa
Aug 24, 2001 03:29 PM
Huckster's '84 TA
Car Audio
Aug 23, 2001 08:54 PM
Mike Harvey
Car Audio
Nov 13, 2000 11:49 AM
