Help requested. After a dash board swap, guage lights do not work.
Old Jun 6, 2016 | 12:03 AM
amfornal's Avatar
Car: 1989 IROC Z L98 G92
Engine: 5.7
Axle/Gears: 3.27 G92
Today I replaced my cracked dash board with another one. Before I took the old dash apart, all gauges and lights worked just fine. Since I was taking apart the dash, I went ahead and replaced the headlight/ dimmer switch. When I got it all back together with the same cluster from before, the gauge lights do not work and the gas gauge pegs past the FULL mark. When I turn the ignition on, the dummy lights all light up like they are suposed to. The volt meter gauge works and the oil pressure gauge works as well. The new headlight switch is functioning properly and the dimmer part of the switch also works with all the other interior lights. Anyone have any thoughts before I go and rip it all apart again?
Old Jun 6, 2016 | 12:23 AM
fokeyman's Avatar
Car: 89 IROC
Engine: l98 350 TPI
Axle/Gears: 373s
Re: Help requested. After a dash board swap, guage lights do not work.
You could try prying your hand behind the dash and wiggle the connectors to the clusters. Might be able to find one misaligned or pushed out maybe.
Old Jun 6, 2016 | 12:30 AM
amfornal's Avatar
Engine: 5.7
I tried that, even pulled the cluster back out and put it back in... Same two things dont work. The gauge lights and the fuel gauge... ground wire somewhere???
THIRDGEN87
Interior Parts Wanted
Aug 24, 2023 01:01 PM
broke91firebird
Sep 2, 2019 10:02 AM
MantyZ28
Jul 24, 2018 07:47 AM
thomashearts
Carburetors
Apr 10, 2016 03:14 PM
utfan01ss
Mar 17, 2016 02:47 PM
