sun visors and idle problem
Old Sep 24, 2016 | 06:42 PM
Just poetic's Avatar
Car: 86 trans am
were can i get oem sun visors for my 86 trans am (tpi)
also how can i make my idle on my car stable
plzz help
Old Sep 25, 2016 | 06:08 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: sun visors and idle problem
http://www.classicindustries.com/pro...82141401t.html
or 1A,T top or hardtop?
Idle could be a list of things.
Old Oct 1, 2016 | 04:24 PM
Car: 86 trans am
it is a hardtop also were can the sterring fluid reservoir be found
Old Oct 1, 2016 | 06:07 PM
gearhead141's Avatar
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
The steering pump and reservoir are located beneath the A/C compressor. That is, if your compressor is on the driver side of the engine. It may be a bit difficult to see, and you may need a funnel with a tube attachment. Be careful not to over fill. If you do, use a turkey baster to remove the excess fluid.
Old Oct 1, 2016 | 07:51 PM
Car: 86 trans am
thank you guys for helping me
also why would me trans am jerk forward when i put it into drive or reverse ??
what kind of steering fluid will it need
Old Oct 1, 2016 | 09:54 PM
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
This is very common to all Thirdgen cars. It can be greatly minimized by making sure the trans mount is securely fastened to the transmission. This means you have to crawl under the car and check that the bolt is tight. It is a good time to check it when doing an engine oil and filter change. Once that bolt has been tightened up, the "clunk" won't be nearly as noticeable. I check mine every time I'm under the car as it often becomes loose.
moneyman380
Nov 19, 2016 06:31 PM
dmccain
Oct 3, 2016 12:52 PM
FormulasOnly
Sep 26, 2016 06:21 AM
IrocJoeCool
Sep 1, 2016 12:48 PM
19irocz85
Aug 31, 2016 02:28 PM
