Power Door Locks
Old Jan 29, 2017 | 11:51 PM
Marc Webber's Avatar
Car: !982 Trans Am
Transmission: 350 Turbo
Axle/Gears: 3.08
Power Door Locks
I am currently putting my 85 T/A back together. I've done very well so far. I've gotten to the point of getting ready to put my new door panels on. I just got power back to the car today and I found out my power locks are not working. Anyone have any ideas?
Old Jan 30, 2017 | 09:47 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Power Door Locks
Here's some trouble shooting info,it's for the 86 Firebird,it's the same for 85
Old Jan 30, 2017 | 11:00 AM
gearhead141's Avatar
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Look at the simple stuff first, i.e. the fuse. It could be as simple as that. If not the fuse, then get the multimeter out and start checking where power is lost.
Old Jan 30, 2017 | 02:11 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yes, check the CTSY or ACCY fuse. If that is blown you also won't have power mirrors, dome light, horn, third brake light, or lighter
Old Jan 31, 2017 | 03:00 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Once your sure the fuses, circuit breaker, wiring is OK;
Unscrew the relay from it's mounting location, replace the mounting screw with a clean one and re-screw the relay back in place. The relay is grounded to the body and this ground can be lost if there is any crud/corrosion in that area.
