Making my own door panels
Old Feb 27, 2017 | 08:34 PM
Destro Camaro's Avatar
Car: 88 Camaro
Engine: 2.8 V6 For Now
After doing a power window conversion I could not stand the hole from the window crank so I decided to try to make my own. Think it turned out ok for my first time.
Still have to sand down some areas, play with some more design ideas in my head, then foam and wrap in vinyl.
Old Feb 27, 2017 | 08:38 PM
Car: 88 Camaro
Re: Making my own door panels
Made a template
Old Mar 3, 2017 | 09:05 AM
DylanMiner's Avatar
Car: 89 IROC-Z
Looks good, when are you going to cloth them?
Old Mar 3, 2017 | 01:49 PM
FirebirdUSX's Avatar
Car: Firebird
Engine: 5737cc
Why not leather? That looks so much better and its so nice to work with it when you have to wrap it.
Old Mar 3, 2017 | 03:26 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
It looks like you are using hardboard so it is still important to use that plastic sheeting behind the door panel so water has less of a chance of rotting, warping or expanding the hardboard. I would also rethink using that piece of wood because it's not going to cover nicely.
Old Apr 22, 2017 | 11:35 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
looks good. Any progress?
