92 vert with GTA digital dash
Old Jun 7, 2017 | 04:50 PM
Claudioa's Avatar
Hello everyone
I'm thinking of putting a digital dash in my convertible and want to know what's involved.......
Ps : anyone have a complete digital dash for sale......??
Old Jun 7, 2017 | 05:17 PM
cdoyle's Avatar
Re: 92 vert with GTA digital dash
I'm not sure about Firebirds, but with the Camaro it takes a lot of work.
You have to replace the entire dash with one that has the digital cluster, and also all the sending units I believe (I could be wrong on that part).
I believe the wiring on the older dash might not line up in the harness the same as your 92, so you may need to repin some of the wires around to match up. So you'll need a tech schematic of both the 92, and whatever year the dash is from.
Old Jun 11, 2017 | 04:18 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
You'd have to get ALL the wiring from a digital dash car, interior and engine side body, the washer sensor, plus the dash and the kick panels unless you plan on re-pinning all the switches that are year specific to the old wiring.
Honestly, if you're asking this question you probably don't have the skills to do the conversion. You'd be better off just going to an aftermarket cluster.
Old Jun 12, 2017 | 07:31 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Why? What about the dash you have now is not working for you?
Old Jun 12, 2017 | 08:23 PM
Claudioa's Avatar
Nothing it's a stock analog dash.....
I wanna install a digital dash from a mid 80's GTA....
My car is a 92 firebird vert.....
Old Jun 12, 2017 | 08:24 PM
Claudioa's Avatar
Just want to know how involved the job is......????
Old Jun 12, 2017 | 09:33 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I would not attempt this unless I had a COMPLETE FUNCTIONING digital dash donor car. Piecing it together would lie somewhere in between impossible and cost-prohibitive. You will need several sensors that are specific, a special washer bottle, the lighting wiring is different throughout the car, and I forget what else. Also the entire dash "frame", not just the cluster is specific to digital dash cars. For the whole thing to work, it's a very involved procedure. You will need complete wiring diagrams from your car and from the car of the donor. As much as I love digital dash, I would say don't bother.
