Lower dash loose ..
Old Jun 16, 2017 | 07:01 PM
BluthndrZ28's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Transmission: 700R4 w/2600 stall
Lower dash loose ..
Gentlemen as you can see in the photo years of age and removing this piece has caused it to become loose .. I want to snug it up again and I'm wondering if anyone has ideas .. there is a piece of carpet like material inside so double sided tape was a no go .. it also needs to be removable for future issues if they arise .. thoughts ???
Old Jun 16, 2017 | 10:41 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Lower dash loose ..
That piece has two torx screws on the front ends and three more across the back. Are they all there and tight?
Old Jun 17, 2017 | 05:19 PM
Car: 1991 Z28
Engine: 5.7 TPI
yeah all are tight as can be .. I'm wondering if they r just too old to snug up anymore
Old Jun 17, 2017 | 05:27 PM
rgauder's Avatar
Car: 1987 Trans Am
Maybe epoxy in the holes and let it dry, then screw it back together.
Old Jun 17, 2017 | 07:17 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yeah, maybe the holes have expanded or stretched or something. Maybe a tiny washer or two on the screw could help??
Old Jun 20, 2017 | 09:33 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I did that to a few screw holes. A little JB Weld on a tooth pick, let it harden, drive the screw in.
https://www.thirdgen.org/forums/memb...ml#post6055349
