92 camaro gauge cluster
Old Jun 18, 2017 | 05:25 AM
Kamatchi's Avatar
I was purchasing a solid car in and out but the speedometer, RPM meter don't move what so ever. However The gas hand, engine light, security and e brake light all work properly I was wondering what the problem could be? when the gas is reved the oil hand moves? The rs has an 350 in it but the speedometer reads 110. Any help at all would be great
Old Jun 18, 2017 | 04:16 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: 92 camaro gauge cluster
No idea, but if you end up needing a replacement cluster I have one that tested all good on my own car . Good luck with yours though!
Henry
Oil pressure generally goes up with engine revving higher
Old Jun 18, 2017 | 11:27 PM
Kamatchi's Avatar
Henry
ok thank you I'll most definitely keep that in mind and what's your price btw? And ok.
Old Jun 20, 2017 | 05:38 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
if your speedo and miles counter don't work its probably your VSS. if your tach doesn't work it could be the circuit board under the tach. there is a member here that rebuilds them for you.
Old Jun 20, 2017 | 10:41 AM
Kamatchi's Avatar
oh ok good looking out on that information and would you happen to know his prices because I'm sure you know I would rather not pay for 450 to 350 for a new gauge cluster LOL
Old Jun 20, 2017 | 03:21 PM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
Like 60$ I believe no more than 100.
Old Jun 20, 2017 | 09:59 PM
Kamatchi's Avatar
OK do you have any of his contact information?
Old Jun 21, 2017 | 01:09 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
Go to his thread.
https://www.thirdgen.org/forums/engi...ml#post6145066
