1990 Firebird horn (w/airbag) not working
Old Jun 24, 2017 | 11:43 AM
punzak9's Avatar
Car: 1990 Firebird Formula
Engine: 305 V8
hi, tried searching but couldnt find an answer. My horn on my 1990 firebird formula isnt working. It has an airbag so not sure how it works or how to go about it since its not straight forward like the ones without the airbag.
Old Jun 24, 2017 | 06:52 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: 1990 Firebird horn (w/airbag) not working
You push on the left and right upper corners for the horn. The little buttons usually break and need to be replaced. If you remove the airbag (4 screws on the back of the steering whee) you will see the 2 buttons
Old Jun 26, 2017 | 09:14 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Also these airbags usually warp to the point that they can't make contact with the horn buttons. Easy fix -- remove the airbag, and cut away the warped white plastic material on the back of the airbag where it's blocking the horn contacts. Still had to do that to mine to get it to work after installing new horn buttons.
Old Jun 26, 2017 | 02:22 PM
punzak9's Avatar
Engine: 305 V8
Cool. Thanks for the replies. Shouldnt be too hard then.
