Remove transmission selector knob - staple is out, stuck?
Old Jun 28, 2017 | 05:27 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Remove transmission selector **** - staple is out, stuck?
So I have the rectangularish kind (not the round one) and twisted and removed the button/spring and the staple was already gone from a previous owner. Should the **** slide up? Mine is stuck tight and I put a lot of twist and lift on it.
Old Jun 28, 2017 | 07:57 PM
kentuckyKITT's Avatar
Car: 2 T-Tops
Engine: 327/305
Transmission: TH350/700R4
Axle/Gears: 3:42/2:73
Re: Remove transmission selector **** - staple is out, stuck?
Being that the staple is missing, my first thought after not being able to remove it would be the previous owner may have glued it on there and probably used something strong... If the staple is out, the thing should literally pull off without any effort.
Old Jun 28, 2017 | 08:43 PM
Engine: 350 TPI L98
Transmission: WC T5
Thanks. Must be glue then.
