How to replace Power Window and rear hatch swithc
Old Jul 25, 2017 | 02:26 PM
jeremyb1988's Avatar
On Probation
Car: 1987 IROC-Z Camaro
Transmission: T-5 5 Speed
Hey there...can some please be gracious enough to walk me thru on here the steps to replace the power window switch on an 87 Camaro and the rear hat release switch? The switches are fine...they just need to be replaced bc the symbols/design is worn off them, the car is also a factory 5 speed...so I assume I have to take the shift boot possibly into consideration and what not. Thanks guys!
Old Jul 25, 2017 | 03:37 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: How to replace Power Window and rear hatch swithc
Just take off the screws holding the shift plate down and lift up and look underneath. It will be obvious what to do next. Unscrew the shift **** to remove completely after you unplug the switches. You will see the tabs on the switches to press in on to free the switches. Just push back in carefully to replace, slide shift boot back down the shifter and plug into the switches again. Replace screws and shift ball- done
Old Jul 25, 2017 | 04:15 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
OOPS
Old Jul 25, 2017 | 06:40 PM
On Probation
Hey thanks! The rear hatch switch...thats just a normal switch right? It's like the other two I mean, it's not like some weird cable or anything?
Old Jul 25, 2017 | 06:45 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Basic switch with a connecting plug on the bottom. Just like the window switches
Old Jul 25, 2017 | 06:48 PM
On Probation
Thanks! This wanna be mechanic will feel proud once I do it lol. Cars been at the mechanic for over 2 months getting some serious work done, can't wait to get it back soon!!!
