Potential 5$ fix to Pivot pin 7 o'clock tilt steering issue
Old Aug 15, 2017 | 10:53 PM
Napster134's Avatar
Car: 1991 Pontiac Firebird
Engine: 355 TBI
Transmission: 7004R
Axle/Gears: 3.27/42 ?
Hi all.
I thought I'd post this in case anyone wanted a temp. solution to the 7 o clock tilt steering wheel issue caused by the loose left hand side pivot pin.
I went to orchard and bought a brass sheet 4 x 10" that's 0.005" thick.
I then cut off a small rectangular peice that will fit around the pivot pin and smashed it in. I'm going to set the tilt and forget it and hope it lasts me a while. Also will be making sure I don't use the wheel to get in/out of the car.
Here's some pictures ... not the nicest looking but it's super tight now and doesn't move at all...
Attached Thumbnails Potential 5$ fix to Pivot pin 7 o'clock tilt steering issue-img_4027.jpg   Potential 5$ fix to Pivot pin 7 o'clock tilt steering issue-img_4030.jpg   Potential 5$ fix to Pivot pin 7 o'clock tilt steering issue-img_4031.jpg   Potential 5$ fix to Pivot pin 7 o'clock tilt steering issue-img_4036.jpg
Old Aug 16, 2017 | 07:31 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Potential 5$ fix to Pivot pin 7 o'clock tilt steering issue
What's at 7 o'clock? The pins are at 3 and 9, so I have no idea what you're talking about
Old Aug 16, 2017 | 09:40 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
I think he's referring to the angle that the steering wheel incorrectly tilts to when the pivot pins are worn.
Old Aug 16, 2017 | 10:06 AM
Napster134's Avatar
Engine: 355 TBI
Transmission: 7004R
Here's a few threads on the matter and some links of oversized pin sellers. Navy02ws6 is right. The issue is that the steering wheel moves down about 1/2" in the 7 o clock direction the springs back up. The issue seems pretty common on these tilt steering wheel setups found in GM, Jeeps, and not sure what other vehicles.
https://www.corvetteforum.com/forums...direction.html
https://www.thirdgen.org/forums/inte...ins-loose.html
https://www.thirdgen.org/forums/susp...-infamous.html
https://www.thirdgen.org/forums/inte...r-housing.html
https://ls1tech.com/forums/general-m...02-f-body.html
https://ls1tech.com/forums/pontiac-f...el-wobble.html
https://www.corvetteforum.com/forums...ng-column.html
http://jimshea.corvettefaq.com/wp-co...D&R322SE05.doc
https://www.corvetteforum.com/forums...pivot-pin.html
http://www.zr1specialist.com/HAT%20W...lumn%20pin.htm
http://www.unbalancedengineering.com/GM/Pins/
Old Jul 17, 2019 | 12:31 AM
Tvette99's Avatar
Car: Corvettes and my honda
How is this brass fix holding up is it still tight since installing ????
Old Apr 17, 2021 | 05:13 AM
Tom_H's Avatar
Car: 91 Camaro RS
Engine: 305, VIN E
Transmission: Manual
Has anyone else did this? How long did it last?
I'm having the same problem and failed VA state inspection. I had other issues with the column and replaced it with a rebuilt unit. That column fixed most problems but left the 7 o'clock tilt intact. The housing looks like a couple hundred which I would like to keep in my pocket if this is a good option. For reference, this is not a daily driver but I do intend to drive it regularly when it finally passes inspection.
