Rear hatch motor
Car: 1992 Firebird
Engine: 3.1 6 cylinder
Transmission: 700R4 automatic 4 speed
Rear hatch motor
Does anyone know where i can find the electric hatch motor assembly for a 1992 Firebird? I have looked everywhere and cannot find one. Hawks third gen has it listed but they do not have any and do not know when they will get more of them. Thanks!
Car: 88GTA
Engine: 5.7TPI
Re: Rear hatch motor
Go see Lon.
http://www.top-downsolutions.com/hatch-pull-down-items
Edit- DAMMIT BOB......beat me to it!
Car: 88GTA
Engine: 5.7TPI
Go see Lon.
Car: 1992 Firebird
They dont have the whole assembly though. I see they have the repair kit and the gear and the motor but its all seperate.
I've got one off a late 91, had it listed for sale a LONG time without even a nibble. They aren't as problematic and they only fit 91.5-92 so theres no demand.
Engine: LS1, LB9, L03
There's also someone on eBay that lists a rebuild service for 1991.5-92s for around $100.
Car: 91 camaro rs
Transmission: 5spd
I would just trash the pull down motor they were designed to fail I've had 3 separate third gen and all with the same issue I spent a lot of money putting everything in it new for it to break again when it got cold outside.I permanently mounted my hatch and works like a regular trunk now.The main issue is some people close the trunk hard and breaks the plastic gears in pull down motor then it doesn't latch.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
https://www.thirdgen.org/forums/inte...-part-out.html
https://www.thirdgen.org/forums/inte...-1992-z28.html
Try these guys,89irocz is a great seller.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Hmmm............
Cadillac used a similar pull down/motor trunk motor assem.
during the 80s-90s.
I wonder if they are the same or have the same part numbers?
They had the same issues as the cam/birds from the knuckleheads
slamming the trunk lid down instead of clicking the lid in place and
letting the pulldown feature do its work...............
during the 80s-90s.
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Hawks motorsports (AKA Hawks third gen) has all the repair parts and assembly.
http://www.hawksmotorsports.com/82-9...or-components/
The slides they have are a good upgrade.
Car: Teal 92 Z28
Engine: 5.7
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Here is a list for the 86-91 pull down motor assembly (thanks to Lon)
and which car/year usage FYI that I asked about above:
Buick: 1980-93 Electra, 1985-93 Park Avenue, 1980-93 Riviera, 1992-96 Roadmaster
Cadillac: 1987-93 Allante, 1980-96 Brougham, 1980-93 Eldorado, 1980-96 Fleetwood Sedan,
1985-93 Fleetwood, 1980-83 Fleetwood, 1980-93 Seville
Chevrolet (Chevy): 1986-91 Camaro
Chrysler: 1989-91 TC by Maserati
Oldsmobile: 1988-93 98 Regency, 1986-89 Toronado
Pontiac: 1986-91 Firebird, 1985-92 Grand Am
So if your parts yard hunting for a hatch/trunk motor assem. you know which cars to look for.
Car: 1988 IROC-Z
