Help with hatch pull down motor..
Car: 1986 IROC Z
Figured out why my battery has been going dead. I noticed today that when my rear hatch is shut the motor pulls it down like it's supposed to do but every 4 or 5 seconds I can hear it clicking. It sounds like it's still trying to pull down or something. I does this every 4 to 5 seconds.
It must have just started doing this. Anyone ever experience this and any ideas how to fix it or what's causing it?
Thanks!
Thanks!
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Help with hatch pull down motor..
Thanks!
Thanks!
I guess you could check to see how much Current its pulling with a multi-meter.
Like the head lights I think its a resistance based system. I can't see much in the way of any kind of computer controls hiding in there.
I plan on buying the TDS pull down rebuild kit. I'm not sure which one I need, I need to take my rear plastics off and take a look at which pull-down my car has. My original one was broke and I *think* when I replaced it, I did so with one from a 91-92 car, and my car is an 89. And there are differences.
Car: 1986 IROC Z
Close inspection revealed a broken nylon guide. I ordered a rebuild kit from TDS. Hopefully that fixes it.
Car: 88 Camaro
Engine: L98 350
Could be the guide broke because of the run on. The reversing switch on these gets gummed up and worn, doesn't break the circuit. I had to put a manual switch on mine under the license plate. New switch is NLA that I know of. Keep us posted on what you find out. Like to get mine fixed right some day.
Car: 1986 IROC Z
Installed the rebuild kit from TDS yesterday and boy, what a difference. that motor works like new. Quick, smooth, and no more clicking. Highly recommended.
Axle/Gears: 10 Bolt 2.73 Open
