Question about aftermarket seats
Old Dec 27, 2017 | 11:01 PM
XRipx's Avatar
I'm planning on a rather long road trip with my T/A, but my seats are over 30 years old and extremely flat and hard at this point.
I'd like to pick up a pair of aftermarket Recaros, an LS or LX maybe. Nothing is in stone yet.
My concern is seat height. I'm 6'8" and I'm reasonably comfortable ergonomically right now, but I'm concerned that these aftermarket seats sit higher than OEM. Even a little bit makes a big difference.
So what are my options? Do they actually sit higher? Is there a way to mod them to sit lower if they do?
Old Jan 16, 2018 | 06:02 AM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
Re: Question about aftermarket seats
Most sit higher due to adapter brackets that are used. Often modification to bracket is needed to get seats lower. But depends on exact seats.
Old Jan 16, 2018 | 07:47 AM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
I also heard you can get seat rails for a 4th gen and the seat should sit lower. not the stock 4th gen rails, but let's say you buy Corbeau seats. Just get the 4th gen Corbeau seat rails for 4th gen
Old Jan 20, 2018 | 02:25 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
you can use Fiero seat rails..and they bolts right in to 82/92 Camaros..and drops your seat 2" in front and 3" in back.. also you can bolt them to other seats. then bolt them in to Camaros...
RCAR7395
May 22, 2011 07:34 AM
CamaroGrlY
Interior Parts Wanted
Jun 1, 2008 08:43 PM
91TPI5.7
Feb 13, 2002 08:32 AM
Matt86Z
Feb 8, 2002 01:44 PM
