cruise control
Old Jan 4, 2018 | 06:44 AM
jcllgo's Avatar
cruise control
i have an 87 iroc z with no tilt steerand no cruise control if i add a new column with tilt and cruise is there a factory connection for cruise in the car already to connect to. i assume they made alot of different options available and just added or deleted items not the wiring but just want to make sure . thanks in addvance everyone
Old Jan 4, 2018 | 11:27 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: cruise control
The Cruise Control Module, pedal button(s) and the harness that connects it to the column will not be waiting inside the dash, You would need to add them separately. The dash harness to cruise harness connections to add the Cruise stuff are there, but the cruise wiring itself is not. If you decide upgrade to the Tilt/Cruise column and need the cruise module/wiring,..... I should have it.
Old Jan 4, 2018 | 11:59 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: cruise control
Wouldn't 87 be a cable drive speedo though?
Old Jan 4, 2018 | 02:12 PM
Drew's Avatar
Re: cruise control
Yes, but as long as the car is fuel injected, it'll have the VSS sensor on the cluster and the harness plug for the cruise harness. By 87 I wouldnt be too surprised if even the garden variety basic LG4 used the VSS signal for something.
Old Jan 5, 2018 | 08:09 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Re: cruise control
I wasn't sure HOW it would get the signal. I really know Firebirds, and I was going to reply to the OP first, but then I remembered Camaros were different. So he would need to get the signal from the cluster, as opposed to the other side of the car for the VSS. Also, the firebirds didn't have the necessary plugs and harness if the car wasn't originally equipped, that's what I was going to say in the first place. He is likely going to have to figure out how to make the connections, it's not like he can get a cruise harness and just plug it all in
mmadden55
Oct 21, 2009 06:17 PM
gixxer92
Mid-West Region
Oct 6, 2005 09:56 PM
89ProchargedROC
Feb 19, 2003 07:48 PM
GTA91
Feb 25, 2001 04:23 PM
