Steering column wiring
Car: Son drives 1989 IROCZ
Engine: 5.7L TPI, AFR 195, L98
Transmission: 6 spd manual
Axle/Gears: Stock
I need some help identifying where the two connectors plug into. Three pics are of a 4 wire connector near the steering column. The last pic is a two wire plug coming out of the steering column, possible from the overdrive switch on the turn signal lever. Any pics showing where these plug into would be appreciated.
Re: Steering column wiring
They plug into each other. Seriously. It's the cruise control connector. Line up the flat tab with the hook with the white hook on the connector, push till it clicks together.
Axle/Gears: Stock
My god, your right! What were they smoking when they designed that plug? I guess my frustration got the best of me trying to look elsewhere for the other end when those two were the only ones left. I will laugh about it.....in about a week.
Thanks for the help.
Camaro kid97
Sep 18, 2014 01:18 PM
SLAYER6669
Jul 31, 2005 10:29 PM
SLAYER6669
Jul 24, 2005 04:16 AM
