What size Bolts needed to replace dash pad
Old Apr 23, 2018 | 03:08 PM
Thirdvert89's Avatar
Bought a car with dash pad not bolted in. See there are 6 bolts up front and 4 by vents what size bolts should be used up front how and how long and what size in back vents
thanks for any help
sg
Old Apr 23, 2018 | 07:17 PM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Re: What size Bolts needed to replace dash pad
thanks for any help
sg
Size 7m if I remember correctly
Old Apr 23, 2018 | 07:26 PM
Drew's Avatar
Depends on if it's an early or late car. Early used Phillips countersunk trim screws across the defroster vents, later used 7mm hex heads with washers. The defroster vent screws are hella-long, the ones under the dash are shorter. The diagrams in the book dont list them, so no specifics...
Darkshot
Aug 5, 2009 07:35 PM
327Chevy
Nov 17, 2008 07:24 PM
compuwiz1937
Jan 21, 2007 11:39 AM
scanman717
May 10, 2004 01:45 PM
Stoopalini
Apr 11, 2002 10:16 AM
