87 GTA Seat Foam
Old Mar 5, 2019 | 06:15 AM
pognoot's Avatar
87 GTA Seat Foam
I have an 87 GTA. The seat upholstery is in perfect condition, but the seat foam could be replaced. Am I reading correctly that replacement foam for the GTA is unobtainium?
Old Mar 5, 2019 | 07:57 AM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
Re: 87 GTA Seat Foam
What's the matter with the foam? If the upholstery is perfect how does the foam get pooched? Foam is obtainable, you might have to spend time looking, but it's there. If yours is just cracked or hollowed, it can be repaired, but again, you have to spend time looking for an experienced upholsterer.
Old Mar 5, 2019 | 08:23 AM
pognoot's Avatar
The seat foam is 32 years old and so it's not quite as robust as it was new.
I was hoping I could find a supplier that sells a brand new replacement.
Old Mar 5, 2019 | 08:37 AM
Bddbrd86's Avatar
Car: !986 Firebird
Transmission: th350
You can use a steam machine on the foam, The steam will expand the foam back to it's original shape and thickness.
Old Mar 5, 2019 | 02:14 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Yes, steam. But if it won't come back, or won't stay, a good shop can hand cut and layer new foam on top of the factory piece. This needs to be done sometimes with new covers, to make them fit tight and not be baggy or loose.
Old Mar 5, 2019 | 06:48 PM
82tarecaro's Avatar
I had this issue and an upholstery shop lined the original foam with a thin sheet of foam to give it more volume. Looked great after that.
E_S
May 10, 2015 07:07 PM
jon_volk
Oct 5, 2003 10:32 PM
88IROCs
Jul 3, 2001 08:10 AM
