Camaro dash and interior trim paint adhesion promoter
Old Oct 5, 2019 | 08:14 PM
AnthonyK's Avatar
I am repairing my 82 camaro dash and some interior trim. I am going to use SEM interior flat black paint for the dash and trim parts. I need to know which adhesion promoter is compatible with the dash and interior trim plastic. It was suggested by SEM tech support to either use SEM sand free or SEM XXX adhesion promoter but it depended on what type of plastic it is. Not sure if Bulldog adhesion promoter is compatible with SEM paint and safe for this plastic either. SEM tech support said to use nail polish remover to test plastic and or check to see if their is a indication on the back of the dash as to what type of plastic it is. The only thing I found on the back was PPO on the back of the dash. Not sure if this is the abbreviation for the type of plastic this is. Any help would be great.
Old Oct 6, 2019 | 12:42 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Camaro dash and interior trim paint adhesion promoter
Most all plastic in out cars is ABS, i think the dash is no exception.
Old Oct 22, 2019 | 04:17 PM
MDDAWG's Avatar
Car: 91 z28
Engine: 387 SBC
Axle/Gears: 3.73 eaton posi
I used Bulldog , worked fine , with SEM interior paint
Old Oct 22, 2019 | 09:26 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Colorbond, worked amazing on painting my leather steering wheel and has held up great. They make plastic paint as well in many factory colors and a prep as well. I haven’t used the plastic paint but probly worth a look.
Old Oct 23, 2019 | 09:22 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I always use SEM brand plastic adhesion promoter
Amazon Amazon
Old Dec 12, 2019 | 06:07 AM
caged91's Avatar
Car: 1986 trans am
Engine: Doing 94 vette LT 1 swap right now
Transmission: need a t56
Axle/Gears: M78(9 bolt)mace locker,3.70
ppo-polyphenylene oxide. very similar to pp-poly propalene. You can use any adhesion promoter thats currently avaible.just make sure you prep your parts correctly. do not use a wax and grease remover on any type of plastic.I use a dilluted isopropyl alcohol solution for a final wipe down before the adhesion promoter.Sem makes a good product,its always good to stick with a products line regarding any refinish steps that they might recommend.They will usually stand behind their warranty then. Ive used sem products over my 34 years of working in a body shop and never had a problem. Just remember, Its all in the prep.
Old Dec 14, 2019 | 07:19 PM
82tarecaro's Avatar
I also used Bulldog with the SEM paints. Worked great. Just make sure the plastic is clean and free of any oils.
86FyrBrd
Apr 18, 2013 07:50 AM
blakecharles
Oct 7, 2009 11:06 AM
TheGoodOld305
Apr 16, 2009 01:52 PM
dans82bird
Jan 28, 2004 10:00 AM
86FireChick
Jan 6, 2003 04:50 AM
