Gauge Cluster Options
Old Apr 14, 2020 | 11:47 PM
xWildxChildx's Avatar
In the middle of an LS1 / T56 swap, into a 1985 Z28 that was factory TPI and automatic, which was later changed to an older carb 350. I will no longer be able to use the original cable setup, as nothing will be driving the cable, and was wondering if anyone has any swap ideas?
I understand there is a converter, but given the price I'd just as soon build a whole new cluster setup. Mostly curious if anyone is aware of any options that can swap in and run from the LS1 pcm like the 90-92 clusters. Thanks guys!
Old Apr 16, 2020 | 10:15 AM
johnw999's Avatar
Re: Gauge Cluster Options
I did the LS swap in my ‘84 Trans Am. And I kept my stock gauges. Your speedometer is probably mechanical. T56cablespeedometer can convert a T56 tailshaft to accept a cable. The guy there has posted on this site, and his conversion worked well. I know you said your car was converted to carburetor. If your C100 plug is still in tact, you can identify the wires that lead to the other gauges.
Mailbox Hunter
Aug 26, 2011 04:41 PM
Trassic
Apr 12, 2011 06:14 AM
adam.binkley
Jul 30, 2009 09:22 PM
85TA383
May 23, 2008 03:13 PM
