Gauge Cluster Swap???
Old Mar 13, 2008 | 01:28 AM
Mailbox Hunter's Avatar
Car: 89 Camaro RS
Engine: 350 TBI
Axle/Gears: 10 bolt/ 3.23 Gear.
I did a search in the forums, and didn't find what i need.
If i have an 89 Camaro with a gauge cluster that goes up to 115mph, can i swap it with a 145mph cluster, and have it still read speeds and rpms correctly ?
Old Mar 13, 2008 | 01:50 AM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
Re: Gauge Cluster Swap???
Yes.
Old Mar 13, 2008 | 04:37 AM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
ok same question but different.. swap from 85mph to a 140mph cluster?? thanks
Old Mar 13, 2008 | 06:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes, as long as your swapping mechanical speedo heads (82-89). If your trip odometer doesn't work, check the following link:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old Mar 15, 2008 | 09:34 AM
iluvmy91camaro's Avatar
Car: 1991 Chevy Camaro RS w/t-tops
Engine: BBC 396 .090 over (414)
Transmission: LS1 T-56
Axle/Gears: Shortened Ford 9, 3.25, discs, posi
Yeah same question somewhat. i have a 91 and the speedo only goes up to 110 and that is not high enough. i dont like the gauges that much either. is the gauge pannel from 82-89's swapable?
Old Mar 15, 2008 | 09:36 AM
JamesC's Avatar
No.
JamesC
Old Mar 15, 2008 | 10:11 AM
cdoyle's Avatar
Only if you swap out the entire dash, the cluster is a different shape in those years.
Old Mar 21, 2008 | 04:40 AM
purpleomega's Avatar
Car: 1982 Camaro Sport Coupe
Engine: 2.8L V6, 2BBL
I have an '82 Sport Coupe, I probably can't, but I figure I should ask, can I swap the gauge cluster out for a digital one from an '84 Berlinetta? Also, can I pretty much swap out any of the gauges from any 82-89, or do I have to change the whole cluster? I basically want to get rid of the dummy lights, I don't mind the 85 MPH speedo. Anyone's help would be appreciated, thanks in advance!
Old Mar 21, 2008 | 03:10 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
The digital is not a direct swap there was some differences with the berly dash from regular models IIRC.
Yes you can swap guages pretty much freely between 82-89 camaros, however if you swap from idjit lights to real (well as real as stock gets) gauges you will need to change your oil pressure and water temp senders.
Also if you go from lights to full cluster you will need the whole cluster with the circuit panel on the back.
Old Mar 21, 2008 | 04:58 PM
I had a feeling the Berlinetta dash was out, I was wondering about the circuit on the back though, glad you told me. The sending units I knew as well, but thanks so much for your help!! Now if anyone can tell me where to post this question, or the answer, I'd be one happy Camaro owner:
I have no courtesy lights, lighter, horn, or constant power to my radio (though I do have ignition power, so the radio is rigged to turn on so long as the car is running). When I tried to change the fuse for the dome & lighter........the car tried to start! I just bought the car about a month ago, and all I know is that the owner before the guy I bought it from was a volunteer firefighter, and he had replaced the front turn indicators with blue lights, and put 2 additional lighters in the dash (presumably to plug in more lights). I'm positive there is a short somewhere, but can anyone tell me anything about this, perhaps where to find the short? I have traced all the courtesy light wires to the firewall, then I cannot tell where everything is going from the connector under the hood. Should I just run a new constant power wire to the lighters & radio? Any help would be much appreciated & thanks again for the dash cluster help!!
Old Mar 21, 2008 | 10:00 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
post your wiring problem on the electronics forum
look at the wiring at the ignition switch on the top side of the lower steering column (white thingy with lots of wires goin to it). See if anything odd is spliced into that harness, since that is the circuit that engages the starter.
Old Mar 31, 2008 | 04:24 AM
Hey, does anybody have a picture or part number of the correct temp sending unit for guages? I just did the swap and that is the only thing not working. The part number I have Borg Warner WT359Z, TSU64. Thanks.
Old Apr 3, 2008 | 10:01 AM
Calaban007's Avatar
Car: 95 Z28/IROC-Z
Engine: LT1/L98
Transmission: 6 Speed/700R4
Axle/Gears: 3.42/2.77 Boo!
My IROC originally had the 145 mph speedo. The speedo and tach are broken. I plan on upgrading to Autometer gauges eventually, but I need something for now. I've found a 85 MPH cluster cheap and was wondering if it would work accurately until I can get the Autometer setup. I'm really just worried about the speed. The other gauges should be the same as the one's in the 145 mph cluster. I assume the difference in the speedo's would be in the actual speedo assembly and it should work fine, is this correct?
Also from the searching I've done here, it seems the V6 and V8 Tachs are different. Is this true? I'm more worried about the Oil pressure being correct than the Tach, but hey, I might as well ask. I'm sure if I put the V6 cluster in I can swap out the Tach from a V8 for a little of nothing, but want all the info I can get.
Old Apr 3, 2008 | 10:18 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
Oil pressure is different depending on engine. Tach is different between 6 and 8. Oil pressure gauges came in 60psi and 80 psi types...both will work, but will not read accurately unless matched with the correct sender. Tach is "programmed" to read for v6 or v8 (counts number of ignition pulses). Other than that, all gauges are plug and play into the dash cluster and are fully interchangable between 82-89 although there may be some variation on 82-84 cars (not sure)
The speedo will work, provided there is nothing else wrong with the system. Most often the cause of speedo failure in these cars with mechanical speedo is not the gauge head itself, it is usually due to a broken or binding speedo cable or a broken driven gear.
before installing the new gauges, check your cable (remove, inspect, lube and reinstall), since you have to disconnect it anyway. If speedo still doesnt work, check the driven gear at the trans tailshaft.
Old Apr 3, 2008 | 10:24 AM
Calaban007's Avatar
Car: 95 Z28/IROC-Z
Engine: LT1/L98
It was the cable that was broken, I've figured that out. At the time though, I was all about getting a Autometer setup and broke the speedo getting it out. So unfortunately I can't use it and still need a cluster. Also my Oil pressure gauge works, but my Tach doesn't. I put a multimeter on the pinouts for the Tach while I had the cluster out, and the voltage moved up and down with the engine rpm. So I assume the tach itself is bad. I'm going to try and clean the connections and see if it will start working again. Other than that, the oil, gas, and voltmeter are fine. Like I said though, as long as my Oil pressure works, I'm not to worried about the tach. Especially since my IROC is a auto. Thanks
Old Apr 3, 2008 | 04:32 PM
I just did the swap and everything is working, including the tach. I have an automatic, 6 cylinder, and now you've got me wondering if my tach is accurate. It idles at 500, can anyone tell me what they their tach reads at, let's say 55 MPH so I can compare? Thanks.
Old Sep 16, 2008 | 12:10 PM
Slow2.8's Avatar
purpleomega, i see your'e from ansonia ct, thats funny because i lived up there for 2 yrs until 05, right off wakelee avenue by that gas station and the pizza place. I also have an idle of about 500 and will tell you what mine is rotating at 55mph. 2.8 89 fuel injected.
Old Sep 16, 2008 | 12:14 PM
I live right down the road! Let know what you come up with, thanks!
Old Sep 16, 2008 | 12:20 PM
denthar's Avatar
Car: !985 Chevy Camaro
Engine: 2.8L
you drive an automatic.... do you REALLY need your tach to be 100% accuate.
I did a gauge cluster i went '85 to '88 (there newer V6 models came with tachs) it went without a hitch. the Tach didnt work, so i wired it myself.... it took a few hours to get in there and install my blue dash lights but ya...thought i'd put my 2 cents in... not sure why.... it was the first thing i did with my car:\ i guess i'm happy with it :P
Old Sep 16, 2008 | 03:11 PM
Slow2.8's Avatar
it stays at about 2300 to 2400 rmps at 55mph. my main reason for reading this thread is because i ordered reverse glow gauges off ebay for 21 dollars and they have the speedo gauge for 145 only not 115. I believe swapping out gauges (from 115 to 145) should fix this without any other work. (except maybe trying to get the odometer to match mine which i would try at the junkyard b4 i buy it anyways) keep smoking hondas with that 2.8 omega on ROUTE 8!!!!
Old Sep 16, 2008 | 10:03 PM
I wasn't that concerned Denthar, just more curious to see if the swap was as seamless as it was suppose to be. Thanks again Slow2.8, I will check it out on my drive home tonight. Love smoking those ricers on Route 8!!
Old Sep 16, 2008 | 10:05 PM
denthar's Avatar
Engine: 2.8L
i just reread my post... sounded kinda hostile. my sorries.
Old Sep 16, 2008 | 11:42 PM
No worries, it's all good!
Old Feb 1, 2011 | 09:44 PM
1987chevycamaro's Avatar
Car: 1987 Camaro
Engine: 383 Stocker
ok i drive a 87 camaro 2.8 v6 with the 85mph gauge and the 3 lights. i was wondering if i could juss swap out the entire cluster with one with higher mph, real guages and a tach? i kno im gonna have to change the sending units, i juss wanted to kno if i take the old cluster out will the new one go right in and all he gauges work without rewiring the harnesses???
Old Feb 2, 2011 | 06:51 AM
JamesC's Avatar
Welcome to TGO.
Yes. https://www.thirdgen.org/gauges
JamesC
Old Feb 3, 2011 | 01:37 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
get a cluster from a v6 car or the tach will be wrong.
Old Feb 3, 2011 | 06:42 PM
Car: 1987 Camaro
Engine: 383 Stocker
thanks zenish, im actually not to worryed about the tach right now anyway cause im building a 350 to swap in... i can deal with it bein wrong for awhile untill i get the money up for the the rest of the parts for the swap
Old Aug 24, 2011 | 11:59 AM
instaldave's Avatar
Car: 1987 Trans AM
Engine: 355 4-bolt, L98 heads, Holley 650DP
Axle/Gears: 3.70 9-bolt
I just picked up an 87 trans am. The stock cluster only goes up to 85mph. I also have an 86 that I'm parting out that has a 140mph cluster. Will the 140 work in the new one? The 140mph is electronic. The 85mph one is electronic also.
Old Aug 26, 2011 | 12:04 AM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
hey 89 firebird with 120 speedo, can i swap to the 140? no problems?
Old Aug 26, 2011 | 08:33 AM
instaldave's Avatar
Car: 1987 Trans AM
I swapped out the gauge cluster in my 87 from a 85mph to a 140mph. No problems at all. Works perfectly. Only thing I had to do was roll the odometer to match the miles of the one I removed.
Old Aug 26, 2011 | 04:41 PM
kmcn47's Avatar
Transmission: 5spd
cool.......i'll head to the junkyard and get that speedo sometime then, guy said he'd save it for me, its in a box on the shelf
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
