Trunk center trim interchangeability question
Old Apr 23, 2020 | 08:12 PM
dapruitt's Avatar
Car: PROJECT car is 89' Iroc Z Convertib
Hello, BRAND-NEW member here. Picked up a solid 89' Iroc Convertible as a project to restore with my son before he heads off to college this fall. We are missing a few interior trim pieces. One is the center trunk trim piece, the other is the passenger side trunk trim piece. (We have the driver side lockable storage box.) I found the center trunk trim piece on Ebay, but it's not convertible specific and I'm not sure if this piece is interchangeable between convertible/non-convertible bodies. Hoping someone can answer this. Thanks in advance!
Old Apr 23, 2020 | 08:14 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Trunk center trim interchangeability question
Welcome aboard dapruitt! I don't knwo your answer, but I'm sure someone will. Sounds like a great project.
Old Apr 23, 2020 | 10:00 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Just make sure you have the version for the pull down motor (if your model has that too).Since the slam shut version has a smaller "hump".There's also the t-top holes for the straps/buckles and the locking cover version that has a ledge to support the lid when you close it, but these two should not affect the interchange-ability.Just a cosmetic difference.
I got mine from a non vert for my car and it fits fine.I also used a non vert spare tire cover, i just had to trim the excess material so it would fit properly and welcome to the forum.
Old Apr 24, 2020 | 07:43 AM
dapruitt's Avatar
Thanks for quick reply. I was hoping that was the answer, will provide more options to find suitable replacement.
Old Apr 24, 2020 | 07:26 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
any pics?
Iroctopless
Interior Parts Wanted
Jul 17, 2007 05:21 PM
