Headliner Issues
Old Jul 20, 2020 | 02:45 PM
88formula5spd's Avatar
Headliner Issues
Hey everyone, so I've been in the process of replacing my headliner. It was sagging so I ripped everything out. The board itself has some puncture holes from the pins I was using to temporarily hold up the headliner. The problem I have run into is that I don't want to lay fabric over the board if all of these dents and such are going to be visible. I'm thinking if I get foam backed fabric it won't be visible, but considering the board itself isn't hard and is more foamy itself, would this turn out ok? Essentially my question is: what kind of replacement headliner have you guys used, and to what effect?
Old Jul 20, 2020 | 04:19 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Headliner Issues
Dents or just pin ******? Pin ****** definitely won't show, dents may, depending on how deep and pronounced they are.
After reading how poorly the aftermarket board fit I patched up my stock board and re-covered with with foam backed fabric. It wasn't very difficult
Old Jul 20, 2020 | 04:21 PM
Dents from pressure. Do you think aluminum tape will adhere well? I might use it to flatten the dents.
Old Jul 23, 2020 | 08:10 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
You need the panel to be as smooth as possible. Any dents or tears in the backing board WILL show through. The headliner material is similar to vinyl in that it shows every mark under it if isn't smooth.
Kevman
May 20, 2007 06:15 PM
Mkos1980
Nov 11, 2002 11:16 PM
