Map Light Bulb Part #
Old Jun 1, 2021 | 11:02 AM
brightonrock's Avatar
This picture is from a convertible with the single map light switch and a tiny light that remains on all the time (HVAC light). Does anybody know the part number for this tiny bulb?
Old Jul 26, 2021 | 10:44 AM
scfbody's Avatar
Car: 1983 Z28, 1991 Z28 & 1985 TA
Re: Map Light Bulb Part #
We sell the led version. Any 194 size bulb will work.
https://screamingchicken.com/1988-92...-mirror-bulbs/
Old Aug 17, 2021 | 11:36 PM
BigCatProf's Avatar
Car: 1989 Firebird Formula
I’ve been looking at the bulbs on the Screaming Chicken site and had a question. I bought 194 LED bulbs for the mirror, but once in, the bulbs work fine, but they somehow keep the dome light wired to permanently on. Without the mirror lights installed, the dome light works normally with the light dimmer switch.
I’ve tried re-wiring the mirror light switches but all combinations seem to result in the same. Before I buy more bulbs from Screaming Chicken, I’d like to know that bulbs is the issue.
Old Aug 18, 2021 | 09:49 AM
scfbody's Avatar
LED bulbs take very little power to come on, so the stock bulb may also be getting a small amount of power but not enough to turn on. The mirror lights and dome light have constant power going to them and then the door pin switch supplies the ground to the circuit which makes them light up. I would check your door pins to make sure they are not corroded, rusty or not working correctly which would prevent a good contact. Or the circuit might be getting a ground else where in the wiring. The ground part of the circuit would cause the lights to stay on.
All the led bulbs we sell have a 3 year warranty so if there is a problem with a bulb you can get a replacement. From what your describing I don't believe it would be a bulb problem. Any led bulb may have the same results your having now.
Old Nov 8, 2021 | 01:41 PM
Gunstar's Avatar
Car: 1991 Pontiac Firebird Formula
Engine: ZZ4 crate engine
I realize this post is a few months old, but that tiny bulb is actually a 74, or a T74. Just in case someone is looking for this answer in the future.
Old Dec 12, 2021 | 07:48 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
The bulb that OP is refering to isn't a 194, as Gunstar mentioned its a 74 bulb which is also used for the an automatic gear selector and the HVAC controls.
Old Dec 13, 2021 | 08:13 AM
scfbody's Avatar
We have been installing the 194 bulbs in the lights on the bottom of the mirror for several years, they fit with no issues and work well. I've had them in my 1991 Camaro for 3-4 years with no issues, still work as well as the day I put them in. I can post some pics when I have some time.
Old Dec 13, 2021 | 10:27 AM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Old Dec 13, 2021 | 10:49 AM
scfbody's Avatar
Originally Posted by Keoman
I definitely should have looked at the OP's pic closer, that is different from the mirror I see the most of with the 194 lights in the bottom and no 74 lights. Was that a convertible only mirror or late 80's? We have had some convertibles and late 80's 3rd gens in here before, but all had the mirror with the 194 lights only.
Old Dec 13, 2021 | 11:00 AM
Keoman's Avatar
FWIW, I believe the ash tray light its also a 74 bulb.
Old Dec 13, 2021 | 11:06 AM
91banditt2's Avatar
Engine: 5.7 HSR
There’s definitely a bunch of inconsistencies between the Camaros and Firebirds, minor things that you would think that would exactly the same across the board to make assembly more efficient and or cheaper.
Old Dec 13, 2021 | 11:15 AM
scfbody's Avatar
Especially on the interior, very few parts are the same. I think the drivetrain/suspension is the only area where they share the majority of parts. Plus in the late 80s they didn't make that many which makes parts hard to find.
Blue86Firebird
Dec 13, 2021 10:25 AM
kevo2k6
Dec 17, 2004 08:05 PM
HamSpiced
Dec 1, 2002 01:21 PM
