A pillar weather strip
Old Jun 8, 2021 | 07:32 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
Hi -
Saw a lot on ttop - not a ton on hard top. Is this the right weather stripping for my a pillars? It looks as tho on my car the insulation is stuck to the pillars- about 2 ft / side. These look to stick to the car..i'm totally confused. Wanna replace them while they're out.
https://www.1aauto.com/1982-92-chevr...e/i/1awsr00108
If not ..would one of these work better? Thanks in advance.
https://www.steelerubber.com/door-we...rip-70-0491-73
https://www.steelerubber.com/door-we...rip-70-0411-73
Old Jun 9, 2021 | 09:19 AM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
Re: A pillar weather strip
Anyone?
Old Jun 9, 2021 | 09:38 AM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
That appears to be the part that goes around the top of the door frame and the window pushes against when the door closes.
As for the A-pillar stuff, I'm not sure that was a separate part, it's glued to the a-pillar
Old Jun 11, 2021 | 09:27 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
You're not being specific enough, but I think you're talking about two different seals. There is a seal that is attached to the a pillar molding, it runs from about the top of the door up to the headliner? Then there is the window seal, that is held in by a bolt in channel, that goes from the front of the glass, up the A pillar, across the top of the window, then down the back of the glass. The first link you provided is for the window seal. The second and third link might work as replacements for the A pillar molding seal, there is not a lot of attempts to replace that, as far as I have seen.
Old Jun 11, 2021 | 09:54 PM
Chopski's Avatar
Car: 1989 IROC
Axle/Gears: 3:42
I found a seal on Amazon for the plastic pillar molding (not the window channel) and used it on my hardtop. Looks close enough. I can dig it up if anyone wants it.
Old Jun 12, 2021 | 03:48 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Always good to see what people have bought for replacements
Old Jun 13, 2021 | 12:09 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I used something that I think was from this thread, but the pics don't show anymore. It works great and has held up for several years.
https://www.thirdgen.org/forums/inte...ulding-re.html
Old Jun 16, 2021 | 01:18 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
Just wanted to circle back. Ordered the D looking one - https://www.steelerubber.com/door-we...rip-70-0411-73 . Shipped pretty fast, and was almost a direct replacement. Also installed with their liquid 3m adhesive. Should come out ok. Thanks for the help!
Old Jun 17, 2021 | 09:28 AM
Chopski's Avatar
Car: 1989 IROC
Axle/Gears: 3:42
They don't sell the one I used from Amazon anymore. Just a D shape seal with adhesive but it worked well.
FormulaEngland
May 9, 2016 08:02 AM
Beaner_88
Jan 13, 2014 01:36 PM
kitt23
Exterior Parts for Sale
Jul 8, 2013 06:28 PM
radiateu2
Oct 18, 2005 02:10 PM
91sleeperRS
Fabrication
Apr 26, 2005 07:29 PM
