weather strip where to get it
Old Oct 28, 2003 | 11:21 PM
radiateu2's Avatar
Does anyone know who has the cheapest weather stripping for our cars yes mine is a t-top. Thanks in advance
Old Oct 29, 2003 | 01:10 AM
Fivespeed85's Avatar
Car: 85 Trans Am TPI
Engine: Big Enough
the only place i know of is the dealership, i have seen some in magazines like JCWhitney or Jegs i think. How bad is your stripping, mine leaks but i think its just where it had separated from the metal, i'm going to try silicone before i waste all that money.
Old Oct 29, 2003 | 01:33 AM
radiateu2's Avatar
Well....having the car painted and doing the inside at the same time so......wanna keep the elements out since this crap is so expensive. Ya know its amazing how expensive things get when we are having fun.
Old Oct 29, 2003 | 08:52 AM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
HERE http://www.hawksthirdgenparts.com/
Old Oct 29, 2003 | 10:02 AM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
got mine at 1aauto.com .. was very nice stuff. Fit like OJ's glove and seals up tight.
Old Oct 29, 2003 | 08:29 PM
LtBlue's Avatar
A1 Auto does sell quality stuff. I have bought my weatherstripping (ttop car), and a ABS Headliner from them.
Old Sep 2, 2005 | 12:32 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: soon to be 3.73's
i bought mine from classis industries, i bought their atfermarket brand and installed them myself. Haven't had a leak since.
Old Sep 2, 2005 | 12:33 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
i got mine at classic industries, i bought their aftermarket weatherstripping and haven't had a problem since
Old Sep 2, 2005 | 01:14 PM
DanTheMan_smlk's Avatar
how hard is weather stripping to install?
Old Sep 2, 2005 | 01:47 PM
casebaseball205's Avatar
not very hard at all. i got mine from my local chevy dealer. my dad is a mechanic so i got it cheap through him. 230 bucks compared to 350 at hawks. i bought some adhesive that has a reaction that melts the weatherstripping to the slot. it was fairly easy. took a little while but it was easy. it came in 4 pieces.
Old Sep 2, 2005 | 05:26 PM
tagta189's Avatar
The ugly part is getting all the old pieces out of the tracks.Also make sure you use sealer between the t-bar and the new seals.Thats where the design flaw is on these cars and that's where the real leak problems are.If you don't use sealer there,even with new seals it will still leak.Also use saran wrap around the t-tops when you first put them on,that way the sealer won't squish out somewhere and stick to the t-top glass and rip everything apart when you take them off the first time.Read the tech articles,good stuff..
Old Sep 3, 2005 | 01:26 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
if you buy the gm it comes in one piece. also i installed mine and it leaks worse, do i need some kind of adhesive? mine just sits in there.
Old Sep 3, 2005 | 03:19 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
use 3m weather strip adhesive. they sell it in black, and any auto parts store will carry it. i used soft seal weather striping on my car. i wasnt particualy pleased with the fit, but i got the whole kit for less than $200, so i wont complain too much.
Old Sep 5, 2005 | 01:04 AM
Xophertony's Avatar
Axle/Gears: n/a
yeah, i think i might get some of that stuff, sounds necicary....
Old Sep 5, 2005 | 01:41 AM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
go to WWW.GMpartsdirect.com they have the gen 2 kit for around $218 and thats the complete kit, heres the PN 10164133
Old Sep 22, 2005 | 05:11 AM
Xophertony's Avatar
Axle/Gears: n/a
well iput some glue on my passanger side. i don't get it. i put new striping on passanger side and it does not seem to fit right. it's OEM GM weatherstriping oh well i filled in the odd spots with the trim sealer. next rain i will update you guys on if it still leaks
Old Sep 22, 2005 | 01:28 PM
Black85sport's Avatar
Car: 91 Silverado
Engine: 350 TBI, EBL Tuned
I got my door weatherstripping for the iroc from summit racing. It fits really nice, and went on like a glove
Old Sep 23, 2005 | 09:01 PM
net_coma's Avatar
Classic Industries or Year One...Hawks seemed over priced. A&M Softseal may have it but I have not looked.
Old Sep 23, 2005 | 10:36 PM
montesa311's Avatar
Car: 83-84 camaro, 95 formula firehawk
Engine: 305, 305ho, 350tpi, 350 lt1, 383lt1
Transmission: 700r4, t-5, t56, m6
Axle/Gears: 3:90, 4:10, 3:50, and more
ummm, i bought mine from advance auto parts.... put some silicone sealer were it slipped ofer the sheet metal, and it worked awsome, dosent leak and the hole thing was like 160 bucks for the t-tops
Old Oct 1, 2005 | 04:57 PM
Xophertony's Avatar
Axle/Gears: n/a
well it rained for about 12hrs yesterday. my driverside leaks like the t-top was off. the passenger side is tight! i noteced three dripps at one point. thats it. no dampness. so today when the sun was out i removed my drivers side weatherstripping and glued the hell out of it. and i put a little more glue in the passanger side where i was getting some leaking. weatherstripping adheasive freaking rules!!!!
Old Oct 1, 2005 | 05:33 PM
Xophertony's Avatar
Axle/Gears: n/a
damnit!!!!!!!!!!!!!!!
it just started raining. water is not good for weatherstripping adheaside while it drys!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
well, atleast i still have half a tube left....
Old Oct 17, 2005 | 02:15 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
what i found made a big difference was i pulled the headliner and looked up through where the t-tops adjustments are, and siliconed all right there to make sure there was no way to let water through. You can obviously see the sky with the headliner out. GM really screwed up here. Also get the tops to seal real good using the adjustment thing, i don't know what it's called but where the pins from the t-top go in. They can be adjusted so the t-top sits right on the weatherstripping.
Old Oct 18, 2005 | 02:10 PM
High Geared's Avatar
Car: 1988 Iroc-Z
Here is a link to Camaro Performers web site. They have an article where they replaced the weather strip in a T-Top.
http://superchevy.com/technical/inte.../0506sc_strip/
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
3.8TransAM
Oct 1, 2015 07:47 PM
Nick McCardle
Sep 10, 2015 08:36 PM
