Cannot replace burned out lights in Stock 92 Camaro CD Player??
Old Jul 28, 2021 | 03:47 AM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
NOTE: That "LIGHT?" is facing INSIDE the casing, AWAY from the front? Not bulbs?
So I have one of the rare CD players in my 1992 Camaro Z28 and noticed only lights in the dots for the radio buttons but nothing else. I am almost positive there were more lit up. I had taken pics years ago and looked at them recently only to discover what appears to only be 2 bulbs (for the dots that are lit up now) and are SOLDERED TO THE BOARD?????
I have not re-opened it up as it's a PITA to get to if I can just see my pictures I took before.
Old Jul 28, 2021 | 08:52 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Cannot replace burned out lights in Stock 92 Camaro CD Player??
Pretty sure those back-facing bulbs act as a resistor or something and are not part of the radio backlighting.
Been awhile since I cracked one of those radios open,... but I'm fairly certain that the bulbs you need to change are mounted to the circuit board closest to the face-plate. ( remove the smaller board,... then remove the larger board that closest to the faceplate ) The backlight bulbs are much smaller & yes,... they get soldered in place.
Ed Steur
Apr 12, 2020 09:43 AM
Paulie84vert
Dec 2, 2016 10:42 PM
fierolover
May 13, 2012 11:36 AM
Dennis-Z28
Jul 9, 2009 10:44 AM
