Door panel schematic as DXF template?
Old Jan 23, 2022 | 12:27 PM
Oliver667's Avatar
Car: Firebird (1991)
Engine: V6 189cui
Transmission: automatic
Hi guys,
I too my 1991 Firebird door panels apart and am planning to clean and keep the original fabric, but replace the foam inside as well as the gross cardboard panel that gives the panel its stability.
I found a shop online here in Germany where they can make custom 3mm thin plastic panels from a DXF file.
The question now is whether anyone of you might have a true to scale schematic of the cardboard piece that I could use to convert the image into a DXF file myself - or if maybe anyone even already has a door panel DXF file somewhere.
I am also planning to use strong 1cm x 2cm magnets integrated into the plastic panel instead of the push pins. Shouldn't be too hard to replace the original push pin locations with fitting rectangle holes to glue the magnets into.
Best regards,
Oliver
Old Jan 24, 2022 | 08:49 AM
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
Re: Door panel schematic as DXF template?
If i had a door card from a Firebird, I would gladly layout a dxf. Unfortunately I only have door cards from a 83 Camaro.
Old Jan 24, 2022 | 11:06 AM
PAformula's Avatar
'83 Camaro should be the same as far as the outer shape and holes for grab handle. Only thing that may change slightly is the upper cutout for the door latch handle.
Old Jan 26, 2022 | 05:00 AM
Oliver667's Avatar
Engine: V6 189cui
I just took a photo, did a lot of measuring... looking good so far.
The magnets will get glued in using epoxy, I am not a fan of having to order push pins from across the Atlantic.
Old Jan 29, 2022 | 09:36 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Good job man.
Johnny Gun
Nov 12, 2021 07:24 AM
siuol
Nov 6, 2016 08:18 AM
Sichno
Aug 29, 2016 04:12 PM
c10chas
Jul 16, 2011 01:39 PM
podiatra
Mar 20, 2011 04:25 PM
