Help with under dash location
Old Feb 19, 2022 | 07:59 PM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
Anyone know what is immediately above this section under the dash? Was going to use some small self tapping screw to mount keyless entry box that is just hanging there at the moment. Don't really want to cause a leak or drill into something important.
FYI...This was someone else photo from this site...It was easier than crawling under that dash again!
Old Feb 19, 2022 | 08:47 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Help with under dash location
Thats probably the cowl area where the wiper linkage is, and where water channels away and dumps out the sides. Maybe use double sided tape instead.
Old Feb 19, 2022 | 09:16 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I was thinking velcro, but tape would work. I don't think I'd drill into that.
Old Feb 20, 2022 | 04:02 PM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
Good call on the double sided tape. I originally made a bracket that mounted to the automatic pedals/brake booster bolts. However, I'm converting to manual and my custom bracket no longer works given the extra brackets to support the manual pedal assembly. I mocked up a new bracket but it would be a pain to take on and off but would work. Not sure the juice is worth the squeeze on this one.
n2deep22
Feb 20, 2022 07:56 PM
1320_Guy
Feb 7, 2009 06:28 PM
My1stRS
May 29, 2002 04:37 PM
