1990-92 cluster in 82-89 for t56
Old Aug 12, 2022 | 08:19 PM
polygaryd's Avatar
Car: 1994 firebird
Engine: 427ci lsx bowtie block
Transmission: tremec t56 micro edged gears
Axle/Gears: Strange dana 60 with racing spool
So I know that a 1990-92 speedo isnt a direct swap into an 82-89 thirdgen. Is that only because the 90 to 92 is eleteically driven vs cable driven or does it not bolt in at all either?
I want to change my 145mph cable driven speedo in my thirdgen camaro to a 90 to 92 eletrically driven speedo so that I can use a dakota digital box and a t56 trans with eletrical speedo output like I did in my 87gta which has the 140mph electrically driven speedo.
I realize that I need the pigtails and would need to run wires to the transmission speed output connector. I just need to know if it will bolt in or not. Dont want to buy a speedo if it wont bolt in.
Old Aug 12, 2022 | 09:26 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: 1990-92 cluster in 82-89 for t56
Won't likely fit in the dash without serious reconstruction. You can make a custom one however. Do some searching for making an electronic cluster for the earlier years. Sure someone on here had done it with pics and details. Have fun!
L98wit
Jan 13, 2013 12:02 AM
dimented24x7
Oct 22, 2007 09:47 AM
NJITIROC
Sep 18, 2002 09:06 AM
