1983 Firebird 5.0 auto speedometer cable
Old Nov 29, 2022 | 08:05 PM
Okaywhatever's Avatar
Car: 1988 TransAm GTA, 1983 firebird SE
Engine: 350,305
Transmission: 700r4x2
Axle/Gears: 327
I have an 83 firebird 5.0
SE automatic and the speedometer cable is broken. It’s torn at the transmission. The car has cruise(and it doesn’t work and I was going to delete it) but am wondering what size cable I need. Rock auto lists multiple options. Thanks
Old Nov 29, 2022 | 08:39 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: 1983 Firebird 5.0 auto speedometer cable
If you're going to delete cruise control the speedometer cable is 76.8in/1950mm long according to the GM parts book.
Old Dec 5, 2022 | 02:19 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
IIRC the early cables ran from the tranny to the CC set-up,... then another - shorter - cable from the Cruise Control into the cabin for the cluster. Later cars (84-89 ?) used a different / longer cable that runs from the tranny directly to the cluster. I'd use the longer 85-89 style cable if you are not using the Cruise Control.
Old Dec 5, 2022 | 02:38 PM
Engine: 350,305
Axle/Gears: 327
I see. So In theory the later cable should work? Or would it be a better bet to get the two shorter ones and have it go through the cruise control
Old Dec 5, 2022 | 08:11 PM
John in RI's Avatar
It's your call; if you wanna' bypass the Cruise,..... get the 1 piece cable and pull that cruise control "thing" right out of there ! ! ! !
tri power
Jun 10, 2008 06:55 AM
