a/c defroster advice
Old Dec 19, 2022 | 02:35 PM
Brysherezz's Avatar
I want to rig up a switch or something that will prevent the a/c compressor from coming on when the defroster is on. Where would be the best place to tap in? Sometimes I just want fresh air to blow instead of the a/c kicking on
Old Dec 19, 2022 | 06:23 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: a/c defroster advice
I'd say splice your switch into the wiring AT the AC compressor. There should be 2 wires leading to it ( 1-voltage and 1-Ground ) cut 1 of them ( I'd cut negative ) & run the 2 wires for the switch into the cockpit and mount where-ever you like. When you turn on the Defroster just flip the switch to kill the voltage ( or ground ) directly feeding the AC compressor.
I should have put WAY more time than 2 minutes trying to figure the best way to do this,...... ( relay ? wire gauge, voltage spikes, ect... ) so after 2 minutes you just got the simplified 'hacker' method ! I would recommend getting the HVAC schematics that are specific to your car for review before cutting anything.
Old Dec 21, 2022 | 02:00 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Why not just disconnect the plug by compressor?
GMP318
Jul 6, 2018 06:00 PM
chops1sc
Mar 5, 2015 11:15 AM
Spd-Kilz
Jul 6, 2012 01:10 PM
Zrated83
Jul 8, 2007 03:43 AM
