Rear seat delete/ compartments
Old Jan 17, 2023 | 12:10 AM
Swapper's Avatar
Sup guys. wanted to share my little project i just started. having owned fc rx7s and c4 corvettes, i always liked the little compartments they had instead of rear seats. anyways ive been looking for a set of these FC compartments for the longest cause i thought i could make them work in a 3rd gen. found a deal on ebay and pulled the trigger. so theyre kinda cool cause theyre not a solid compartment. theyre more of like a bag. they have lights in each pocket which i gotta decide if i wanna wire those up or not. so with a little bit of trimming i got them to roughly fit in. i still need to trim some more and add extensions to the lower front half. then ill find some dove grey carpet or something close to cover it in and should be good. been thinking making the passenger side one my battery relocation area.
Old Jan 17, 2023 | 09:35 AM
BajaDaze's Avatar
Car: 1989 IROC vert UMI sus w/1LE brakes
Engine: 1990 ZR1 LT 5, alum flywheel
Transmission: Tick built T56
Axle/Gears: 3.7 Borg Warner
Re: Rear seat delete/ compartments
I like it, great idea for that space. Can't wait to see the finished product.
Old Jan 17, 2023 | 10:03 AM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
Thats a really great idea. Looks really good.
Old Jan 18, 2023 | 07:29 AM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
love it, was hoping id find this here after seeing you post it on the gram. keep up the great work!
Old Jan 18, 2023 | 12:30 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
What car did those come out of? They fit really well as is.. Pretty neat idea.
Old Jan 18, 2023 | 01:46 PM
pirateofms's Avatar
Car: 1989 Firebird
Engine: 2.8 V6
Oh, wow. I was planning on building something like this already, but it looks like this might be an easier/faster route.
Old Jan 18, 2023 | 02:15 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Schrader used to offer delete kits for 4thgens long ago. I'm thinking they might've made them for 3rdgens too, but if so, then it was only for a short time, most likely due to the usual reason.
Shrader Performance – Custom Dyno Tuning – Modular Ford & Coyote
They currently offer kits for newer cars. Some of the kits look like they might be doable in a 3rdgen, but it would take some info from Schrader about the different applications.
There are a lot of pictures online and in 4thgen forums of their delete kit installed in 4thgens. It was nice, compartmented and looked more involved than the current kits they offer for newer cars. I think someone here on TGO, sometime ago, posted pictures of his installation of the 4thgen kit in his 3rdgen. The rear seat areas aren't very different, so the fit wasn't bad.
Maybe someone could get Schrader to revive the 3rdgen and/or 4thgen kit.
Old Jan 18, 2023 | 10:52 PM
Swapper's Avatar
thanx everyone. slowly working on it here and there when i get a chance. finally stopped raining on the weekends so i should be able to get at it some more.
Old Jan 18, 2023 | 10:55 PM
Swapper's Avatar
theyre from a 85-92 mazda rx7. not sure if they all have them or not. i know at least for me theyve been pretty dang hard to find locally.
pic of a rx7 for example.
Old Jan 18, 2023 | 10:57 PM
Swapper's Avatar
yeah ive tried looking for pre-made delete kits but doesnt seem like anybody sells them or if they do theyre just over price flat pieces of carpeted plastic. the hawks one are a big joke. just a cover that goes over lower seat mount.
Old Jan 19, 2023 | 12:04 AM
Swapper's Avatar
found some real thin sheets of wood at work to help me figure where and how this thing is going to mount. got it sitting about level with the side arm rests. im going to make the pieces longer and cover the holes on both sides. i think once everything is covered with carpet it should look half way decent. also gotta find spray paint to paint the lid covers ( i kinda wanna paint some other interior panels too). i took the bottom out of one of the compartment and had to trim where the lower seat rod things slide into the seat. i was going to use those quick latch things to hold them in but with the front screwed into the lower bracket it holds the hole thing it pretty good. might have to make something for the rear though.
Old Jan 21, 2023 | 10:14 PM
Swapper's Avatar
so i redid the front pieces to come to the edge on the door opening, added poster board to fill in the center piece then covered the seems and screws with duct tape to cut down on seems and bumps. got 1.5 yards of med grey carpet from a local upholstery shop, some of their preferred glue and some interior paint. wrapped the whole thing in carpet. cleaned and scuffed the plastics on the flaps then 2 coats of paint. put the compartments in and screwed everything together. i still gotta removed the seatbelts. loving how it looks. came out better than i was expecting.
Old Jan 21, 2023 | 11:31 PM
LAFireboyd's Avatar
There it is. That's what we wanted to see, pictures with the lids closed so we could see how it looks back there. And it looks very good. Nice work.
What kind of material was the original piece made from, and what kind of material did you use to complete it? I'm curious about how heavy the completed project is.
Old Jan 21, 2023 | 11:50 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Wow, I like this idea a lot. I feel like it would be easy enough to diy the basic shape except those lids are really nice.
Old Jan 22, 2023 | 12:22 AM
Swapper's Avatar
thanx. the original piece i wanna say is like a plastic/ fiberglass mix. its kinda weird. a little itchy cutting it. i just added some pieces of pretty thin wood on the front and some poster board to fill in the upper portion of the front part to make a smoother transition. it really doesnt weight much. maybe at the most like 8-10 pounds.
Old Jan 22, 2023 | 12:24 AM
Swapper's Avatar
my original plan was to just make a shelf like most seat deletes but having owned a few rx7s and seeing these in my bros rx7 i just thought itd be cooler and i was right. lol.
Old Jan 22, 2023 | 12:00 PM
scarbucket's Avatar
Car: 1987 Firebird Formula
Engine: 355
Transmission: Borg Warner 5 spd
Axle/Gears: 3:43
You should make molds and sell those. I like that a lot.
Old Jan 22, 2023 | 09:43 PM
Swapper's Avatar
i wish i could but thats way above my skill set.
Old Jan 23, 2023 | 12:05 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
I would also like to purchase this, if you measured it and we could find the person with the right tools, this would be an amazing part to have.
Old Jan 24, 2023 | 10:47 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
That's awesome!
Old Jan 24, 2023 | 11:19 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
This is a cool idea. Looks like you could make the whole thing out of wood. The top piece could have the edges cut to match the panel curves better or just sit on top of the rear armrest pieces. Cut another piece of wood for the front and match the profile of the floor / middle hump. Cut some holes in the top wood piece for the compartment pieces. Carpet the whole thing, install the compartments and whalla!
Old Jan 29, 2023 | 02:14 AM
Clements408's Avatar
Car: Son drives 1989 IROCZ
Engine: 5.7L TPI, AFR 195, L98
Transmission: 6 spd manual
Axle/Gears: Stock
Great idea. Here is my version of a lockbox made from steel to keep valuables safe when the T-Tops are off.
Rough check with Roll bar
Rough check in the IROC
Carpet and lock installed
Lid open, amplifier installed
Final installation
Old Jan 29, 2023 | 10:35 PM
Swapper's Avatar
dang that thing is crazy. good fab work though. i like it
Old Mar 15, 2023 | 11:27 AM
ermandadana's Avatar
Old Mar 15, 2023 | 02:02 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Here's my take I did a few years back. Might take the carpet off and use it as a pattern to make out of fiberglass or something lighter than 3/4" plywood. Been dragging my feet since I can't decide if I really want to only have a 2 seater.
Lockwood
May 4, 2018 09:57 PM
johnw999
Jan 11, 2018 10:33 PM
F_N_JUNK
Jun 2, 2008 05:55 PM
85 T/A WS6
Pacific Northwest Region
Sep 24, 2001 05:24 PM
