GTA headrest
Old Feb 17, 2024 | 07:33 PM
tunedport77bird's Avatar
GTA headrest
How do you disassemble a GTA headrest? TIA
Old Feb 24, 2024 | 01:31 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: GTA headrest
to remove it from the back of the seat i"m going to say use a metal type ruler and stick it down the back between the metal section of the headreast
and wiggle up and down till the headrest comes out.
Old Mar 1, 2024 | 04:03 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: GTA headrest
IIRC, (and this is from memory 20 years back, so proceed with caution)
The actual pad is clipped on. It pulls off the headrest, from there are two screws that hold the plastic cover in place. The two ***** have a screw behind the round rubber covers (they just pull off). Before you stick a ruler in, pull the accordion boot off from the underside of the HR, but be careful, it rips easy. The seatback side is held on by a plate/screws, but you have to slide the HR out of the seatback if you want to remove the boot.
Travis odell
Members Camaros
May 1, 2008 04:08 PM
1FSTGTA
Feb 26, 2003 09:42 PM
DOOSKI
Oct 11, 2002 04:51 AM
fl87gta
Oct 9, 2002 01:47 PM
