GTA Headrests
Old Dec 2, 2024 | 02:50 PM
ksr's Avatar
ksr
Engine: 5.7 liter V-8
Transmission: 4 speed auto
GTA Headrests
Minor issue. The headrest on my passenger-side seat always slides back down to the lowest position while I'm driving.
Does anyone know if there's a way to tighten this so that it stays in the chosen position?
Old Dec 5, 2024 | 06:38 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: GTA Headrests
When i had these seats way back, i put a foam block inside the little accordian piece between the headrest/seat. It helped some, but not much of a solution. All that keeps the HR from coming out is a flat spring that locks into a hole on the slider. That spring also puts tension on the slider, but i dont remember a way to put more tension on it.
Old Dec 6, 2024 | 07:01 AM
ksr's Avatar
ksr
Re: GTA Headrests
Thanks. It's a minor issue that I'll likely just have to live with. I'll try something similar to what you did with the foam.
tunedport77bird
Mar 1, 2024 04:03 PM
Drgnbld
Interior Parts Wanted
Feb 15, 2022 11:41 PM
coscob
Jul 9, 2006 05:43 PM
