91 Firebid Door cupholder
Car: 1991 Pontiac Firebird Trans Am GTA
Engine: 5.7 350
So I have the passenger side with no bolts and just ordered the drivers side. Can anyone tell me what size bolts are needed to put these on?
Engine: 4++,350 & 305 CIs
Re: 91 Firebid Door cupholder
IIRC, They are very similar to whats in the lower armrest.
adjust the length to fit correctly.
Transmission: Pro-built 700R4
Just be careful to not over torque them. As you probably already know, those mounting points are fragile.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
As mentioned, same as the two lower ones on the arm rest. Not the upper, thats wat long and the little square plastic inserts are used on various places. Like the rear license plate.
I leave mine about 1/32 loose, as mentioned also. Those mounting points are somewhat fragile.
kaptinkafeen
Dec 1, 2018 12:00 PM
whitedevilTA
Jan 28, 2011 05:08 PM
