Seat recline adjustment
Old Jul 3, 2025 | 12:12 PM
Jaxbeachdawg's Avatar
Car: 91 Camaro
The recline adjustment is stripped from rear seat passengers pulling on the seat back to exit,easy fix?
Old Jul 3, 2025 | 01:54 PM
gbeaird's Avatar
Car: 1985 Firebird & 1992 Camaro B4C 1LE
Engine: 310 LS1. & 305
Transmission: TH350 & T5
Axle/Gears: 9" 3.73
Re: Seat recline adjustment
IIRC, there is no 'adjustment' per se, other than the adjustment that's there with moving the lever. It's spring-loaded meshing gears. You can pull the cover off to make sure no junk or corrosion have made meshing the teeth of the gears difficult, otherwise I believe you'll have to replace the mechanism. 4 bolts hold it to the seat, though, and while the fabric and foam will wear with age, unless the one you get to replace it with came from a car where the little snot lockers were yanking on it, you should be good to go.
affliction1
Sep 18, 2011 05:40 PM
JamesC
Feb 17, 2006 06:39 AM
Berlinetta
Oct 1, 2004 07:37 PM
JamesC
May 3, 2002 01:31 PM
