Pull down unit
Old Mar 28, 2026 | 06:36 PM
zrhody's Avatar
Pull down unit
Anyone know why my pull down unit isnt moving up or down? It has plenty of power n i recently replaced the plastic guides
Old Mar 30, 2026 | 03:47 PM
scottycamaroz28's Avatar
Car: 89 PONTIAC TRANS AM
Engine: 5.0 TPI
Transmission: Stock 4SP 700R4
Axle/Gears: 4TH GEN 3:23
Re: Pull down unit
If the motor is or was working properly I would think it is one of 3 easy things to check. The easiest is to check the fuse. When my fuse blew out my hatch light went out as well. I changed the fuse then the light and motor worked. Second part to check if the fuse is good would be the relay behind the panel. If the fuse is good, relay is good and you have a known good motor it might be the limit switch on the pull down assy itself.
Old Apr 1, 2026 | 05:09 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Re: Pull down unit
There have been different versions of the pull down unit. Which one do you have?
If it's the one with the big black switch box in the middle, that used to stick from time to time on my one.
If you have a thin long hook, you may be able to give the lever on that box a push or pull. May help.
timonator
Dec 11, 2023 05:28 PM
mongoosekeith
South Central Region
Apr 26, 2009 09:13 PM
burrabb1t
Aug 16, 2008 08:09 PM
fattie92
Sep 18, 2002 07:54 AM
