LSX and LTX Parts Looking to buy or sell LSX or LTX parts? Post it here.
[Wanted] lt1 intake modded for distributor
Old Jun 24, 2012 | 12:17 AM
Theman0188's Avatar
Car: 76 Corvette Stingray
Transmission: TH350
Axle/Gears: Stock
I am going to try my luck on this one. I am looking to put an lt1 intake on my block instead of tpi... so, I was hoping someone had one that had already been modded for a distributor. I understand that there are more mods needed to make it fit right, but the distributor hole and spacer is the only part that makes me nervous, so before I just grab a stock one and hack away, I wanted to see if anyone happened to have one with this done.
Old Jun 24, 2012 | 08:25 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: lt1 intake modded for distributor
pm sent
Old Jun 28, 2012 | 05:36 PM
project89's Avatar
contact streetlethal he has a lt1 intake or atleats had on almost ready to go, not sure if he ever sold it or not.
he modified his differently then most though , he cut out the section were the dizzy would go then cut a sbc intake that had the dizzy hole so it fit exactly right into the lt1 intake .though i dont belive it was welded up yet.
if it needs to be welded it would be as simple as bolting it to a block lining up the dizzy piece droping in the dizzy to align everything and then tacking it in place. remove the intake and finish welding it up
Old Jul 2, 2012 | 01:37 PM
Theman0188's Avatar
Transmission: TH350
Axle/Gears: Stock
I ended up buying one from aliceempire, but thanks for trying to help.
-Wes-
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
fbirdroller
Sep 2, 2015 10:27 PM
