[Wanted] LT-1 AIR injection tubes
Car: 91 Corvette
Engine: 5.7 TPI
Transmission: ZF6
Axle/Gears: 4.10
I'm looking for two of the 95-97 right side air injection tubes for an LT-1. I need 2 because I want to use them for an LT-1 manifold swap on my 91 L-98 Vette. I also need the fitting that screws into the manifold.
If you have one or two of these, please let me know.
I can only use the one that looks like this (don't need the check valve, just the tube and fitting):
Re: LT-1 AIR injection tubes
Car: 91 Corvette
Engine: 5.7 TPI
Transmission: ZF6
Axle/Gears: 4.10
Thanks, but it turned out that they wouldn't work for what I need to do. I built a set instead.
1992 Trans Am
May 10, 2023 07:19 PM
toronto formula
Nov 10, 2015 06:17 AM
