LSX and LTX Parts Looking to buy or sell LSX or LTX parts? Post it here.
[For Sale] SOLD
Old Mar 13, 2015 | 04:57 PM
Mdenz3's Avatar
Car: 91 RS
Axle/Gears: 3.42 LSD
SOLD
heads are sold
cam sold
injectors are sold
Old Apr 8, 2015 | 02:51 AM
turbota82's Avatar
Car: 1989 Formula
Engine: l98
Re: LS heads/cam kit $1750 shipped
Originally Posted by Mdenz3
I have a set of nicely ported LS1 heads, they flow over 300 sfm on the intake side and include .660" Brian Tooley Racing lift dual valve springs with titanium retainers. The casting number is 853.
The cam is a 230I/233E duration, .625I/.611E lift Bullet racing custom grind.
There is also a set of (8) 42lb injectors, the ideal size for the heads and cam.
New in the box ARP 234-4316 12pt head studs for 2003 and earlier LS blocks.
A texas Speed ported LS6 oil pump.
I carefully specced these parts out to give an honest 450rwhp with the supporting mods, I'm only selling them because I have decided to go with a blower setup instead.
All you'll need to complete this is gaskets, fluids, and time! I can even help with tuning if you want.
Just have some questions for you about this set up and what supporting mods will get you to the 450 hp. I'm doing a ls swap and want to up the hp from the factory engine. My engine is out of a,2001 ws6 and already has the ls6 intake on it. I plan on adding long tube headers and want to do a head and cam swap. Any way call or respond thanks. Chris 803 220 7297.
Old Apr 8, 2015 | 09:18 AM
Mdenz3's Avatar
Car: 91 RS
You'll need a bigger fuel pump (Walbro 255lph), a tune, and I'd recommend an LS2 timing chain while it is apart. Depending on the mileage you may want to get new lifters also.
Also once you get the heads assembled on the motor you'll have to measure the pushrod length and get those.
Old Apr 9, 2015 | 05:22 PM
Mdenz3's Avatar
Car: 91 RS
Re: LS heads/cam kit $1150 shipped
Bump, The ARP studs and LS6 oil pump are no longer available.
Old Apr 9, 2015 | 11:59 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Who did the portwork on the heads? Do you have a flow sheet?
Old Apr 10, 2015 | 10:02 AM
Mdenz3's Avatar
Car: 91 RS
The heads are sold.
92rsvortec350
19
Oct 9, 2015 09:39 AM
bjpotter
Oct 2, 2015 09:12 AM
Dragonsys
Sep 25, 2015 03:51 PM
Night rider327
Exterior Parts for Sale
Sep 25, 2015 04:23 AM
pmacfadden
Sep 17, 2015 01:06 PM
