[For Sale] Forged 2006 L33 (aluminum) turbo 5.3
the engine only has about 800 miles on the build. With a dyno tune this engine can make 800wrhp easy. Stock Crankshaft
Forged Scat I-beam 6.100 Rods 7/16 ARP Rod bolts
Weisco K474M96 Forged Pistons
OEM 317 Cylinder Heads 5 angle valve job
Lingenfelter GT7 Camshaft and Patriot Gold Springs
Hardened Pushrods OE rocker arm assemblies
Stock MLS Head Gaskets/TTY Head bolts
Stock F-Body Oil Pan
Stock 2006 PCM w/ 2 Bar SD enhancement tuned up to 12 PSI @ 12 deg. of timing. Spikes to 8 PSI and settles to 5 PSI with controller off.
Precision T4 76/75MM JB Turbo
304 SS custom fabricated tig welded hot side
Dual 44MM Waste gates-open dumped
OBX 50MM BOV
OBX 50MM BOV
