383 LT1 block, crank and rods $300 OBO, Oakland, CA
This may be a longshot, but I figure i'll see if there's any interest.
I have a LT1 block that has been bored out .03 and has machined reliefs to work with a 3.75" stroke crank . The crank is Eagle's cast steel LT1 crank (10352375057E) and has been ground .01 under about 2000miles ago. The rods are Eagle I-beam SIR5700BBLW. I had a machine shop re-hone and install the .03 pistons when I built it, but I think he was too aggressive with the hone and didn't check vs the pistons, as it has piston slap currently. The blocks are good to .04 over though, so it should be okay with a overbore and new pistons, rings and bearings. I'm located in Oakland, CA and would prefer local pickup, but could arrange shipping if someone is really desperate. I have a stock, rough condition oil pan on it to protect the crank and the block will be shrink wrapped.
