LT1 no start
Old Apr 13, 2005 | 11:01 AM
Deathtrap's Avatar
Car: 1991 Firebird
Engine: 94 to 95 cam conversion 5.7 LT1
Transmission: 700R4 Mega Raptor
Axle/Gears: stock ax with 323 zexel posi
LT1 no start
I have LT1 in my 91 firebird been driving it for about year. Had it sitting for while through winter. Went to start it and it wouldnt start. Hooked fuel pressure gauge up check for bleed off sure enough 6,8,1,3 injectors where stuck. So I thought that would be a definite problem. Sent them off had them cleaned flow tested. All tested good once cleaned. Drained fuel tank got rid of any bad gas problems. Fresh gas and injectors in. Pressure check good pressure no drops. Crank, crank, crank no start. Did ICM test opti is triggering the coil to fire. Spark test all cylinders are firing. Dropped new plugs in still no start up. Hooked noid light number one injector crank, crank, no light flashing. Checked all injector wires back to PCM all tested good. Is it opti or PCM crapping out. Would a good scanner tell me PCM or if it opti? Or is there simple test I can do with multimeter check PCM with? Or could it be a sensor causing PCM not to pulse the injectors? Like IAC or etc Any ideas thanks I keep on fishing.
Old Apr 14, 2005 | 03:21 PM
Deathtrap's Avatar
Car: 1991 Firebird
optispark
I get spark with sparktester at coil that mean optispark good or bad?
Old Apr 14, 2005 | 08:38 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Check to make sure you have power on the injector wires. They should receive IGN power and are pulsed to ground.
Old Apr 15, 2005 | 10:40 AM
Deathtrap's Avatar
Car: 1991 Firebird
optispark
Optispark was dead only year old put in new one fired up soon as i turned key over. YEEEEHAAAAWWWW
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
