LT1 swap needs?
Old May 26, 2005 | 09:52 AM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
LT1 swap needs?
Are the 4th gen radiator and dual fan setup an absolute must for the swap of the LT1 into a 3rd gen? Currently, I have an aftermarket aluminum radiator and a high output single fan I just wanted to make sure before going any further. Also I need to know if the fuel tank needs to be dropped for this application to install the new fuel lines? And if so does the rearend have to be dropped to access it? In addition to those few questions I would like to know if a new throttle cable is needed from an LT1? And last but not least if anyone has ever done the swap and did their own wiring I would like to know how difficult it was on a scale of 1-10 and how much time did it take to complete the process and get the car running error free?
Thanks for all the help
Old May 26, 2005 | 03:01 PM
TexasLT1's Avatar
Car: '92 RS
no, rad. and fans are not necessary, you can use the thirdgen ones.
fuel pump is fine for a stock engine, put in a 255lph pump if you plan upgrades
use your TPI cable
wiring = 5
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
