LT1 question TBI or TPI?
Old Jun 9, 2005 | 11:02 PM
winsor33's Avatar
Car: 91 RS
Engine: 305 TBI
I have a 305 tbi and was wanting to do an LT1 swap. I was wondering if it would be easier and almost as good if I used a tbi from a 454 or holley instead of the tpi system?
Old Jun 10, 2005 | 07:02 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
No
The LT1 is a completely different breed of SBC since the intake has no water passages in it and is reverse flow cooling. AFAIK the intake that came on the motor is the only one that will work. GM makes a carb intake you can swap to, but would be best to keep the fuel injection setup. Also, the setup is different than TPI so it's not considered TPI.
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
