exhaust problem
Old Aug 17, 2005 | 10:00 PM
mrfbody's Avatar
exhaust problem
i doubt any1 has ran into this be4 but may have some suggestions for me.
87 gta undergoing lt1 swap. has long tube headers with subframe connectors(kinda tight under there).
anyway the shop that fabbed the exhaust messed up a little.
oops might help 700r4 btw
on the driver's side the exhaust is too close to the tranny linkage and i can't get that piece to connect together.
it is weird on mine, like right where the tranny linkage goes into the bracket, there are like 2 plastic pieces that connect together and it will keep popping out of place.
i really don't want to have the exhaust redone, i was thinking of reworking the linkage slightly.
should i try a) mangeling the bracket some? b) getting a different style of linkage and see if it fits?
that all i can think of for now, any other suggestions would be appreciated. thanx.
Old Aug 18, 2005 | 01:34 PM
Firebat's Avatar
take it back to the shop and tell them nicely how they messed up. They should fix it free of charge.
Old Aug 29, 2005 | 02:40 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
heat up the exhaust pipe..... put a big socket or a pipe on it and beat it in with a hammer a bit.
it will make a nice indention and should keep things clear of your linkage.
good luck.
Street Lethal
Apr 30, 2019 12:14 PM
dyeager535
Aug 28, 2015 08:10 AM
db057
Aug 22, 2015 08:17 PM
gta power
Aug 13, 2015 06:15 AM
