93 lt1 runs like ****...HELP!!!
Old Sep 1, 2005 | 10:39 PM
polishdevil's Avatar
Car: 88 GTA
No not a thirdgen, its my Vette but the corvetteforum hasn't been that helpful and since more thirdgenners wrench on their own car i figured you'd be more knowledgable.
I have a 93 LT1, auto with 57K miles. The car has slp shorties, slp cold air, hot cam kit, stage 2 heads, and a ported/polished/coated intake. The tune was done by Nathan Plemons for the third time (Thank you sir :-))and it still doesn't run right.
I am very doubting that the tune is causing the problem because you can start the car up and it will idle and run fine, then turn it off and restart it and then the troubles begin. The car will idle rough and die if you put it in gear without giving it some gas, it also dies at stop signs and has these other symptoms: extended cranking to start, rough idle, sputtering, backfiring, trouble reaching higher rpm, black smoke from exhaust. There is also a misfire from and above ~5300 rpm no matter how the car is running.
The car does not throw any codes and the only thing mechanically that may not be set 100% is the roller rockers (they're loose if anything). I know the above symptoms are for a bad opti but it doesn't make sense its a bad opti if the symptoms are intermitent, although they all do occur every time. The plugs and wires have less than 7K miles and the modifications were done less than 1K miles ago.
The car went from running consistent 14.0's at 99.9 to 13.7's, 13.8's 13.9's at 101...great improvement for $2K lol. It did however put down 323 rwhp and 343 rwtq on the dyno.
All questions, comments and suggestions are greatly appreciated.
Thanks in advance,
Dave
Old Sep 3, 2005 | 05:02 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Swap the Opti, sounds like the optical sensor is crapping out which is generally what happens.
Old Sep 5, 2005 | 04:00 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
wooooohoooooooooooo, opti of doom
Old Sep 5, 2005 | 10:20 PM
Car: 88 GTA
would you guys say that both problems are being caused by the opti? wouldn't it just go out and not be intermittent like this?
Old Sep 5, 2005 | 10:52 PM
Klortho's Avatar
Car: 1987 GTA
Not really, I have talked to a couple of people who say that when the optical sensor starts to go, it can be intermittant. The biggest thing that points to the opti is the misfire above 5300 which is about a 98% happening.
Old Sep 5, 2005 | 11:54 PM
Car: 88 GTA
i love this site and how knowledgable you guys are!
so what do you recommend i replace the opti crap with?
stock opti can be had for $350
dynaspark runs $600ish
ltcc or the delteq are $600+ but don't really remove the opti
so which one should i go with???
Old Sep 6, 2005 | 10:57 AM
Klortho's Avatar
Car: 1987 GTA
Go back with the opti, I know someone who has a built 383 in his Z28 and went with the delteq and it still isn't running right, the opti is good for about 6500 RPM
Old Sep 6, 2005 | 03:52 PM
Car: 88 GTA
i'm willing to swallow the $250 difference and go for the dynapark but i'm not sure if it is all that superior. a couple of people have gotten bad opti's off of ebay latley.
Old Sep 21, 2005 | 02:54 PM
Perry93TransAm's Avatar
Car: 97 WS6 T/A
Engine: LT1 383
I think you have a couple of problems, one being the opti, possibly only the rotor.
I would check grounds for the ecm and have the ign module checked.
The opti , in my experience, will give a high and mid rpm miss regularly, but act like youre talking if any moisture is around.
Usually if it acts up too bad it throws a high or low pulse code.
Old Sep 28, 2005 | 08:14 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: 93 lt1 runs like ****...HELP!!!
Originally posted by polishdevil....you can start the car up and it will idle and run fine, then turn it off and restart it and then the troubles begin. The car will idle rough and die if you put it in gear without giving it some gas, it also dies at stop signs and has these other symptoms: extended cranking to start, rough idle, sputtering, backfiring, trouble reaching higher rpm, black smoke from exhaust. There is also a misfire from and above ~5300 rpm no matter how the car is running.
Are you still running the stock O2 sensor? Sounds like when she reaches closed loop, you're problems then begin.
Old Sep 28, 2005 | 11:07 PM
Car: 88 GTA
it does the same in open and closed loop
Old Sep 29, 2005 | 06:31 AM
Originally posted by polishdevil.it does the same in open and closed loop
You mentioned that you'll start the car up, and it will idle and drive just fine. Are you saying that it only acts up after you shut it down, and then restart it?
Old Oct 1, 2005 | 08:16 AM
Car: 88 GTA
Sorry if i mislead you... I can start the car up one day and it idle problem isn't there. I can start it up the next day (car is cold both days, weather is exactly the same) and it runs like ****. It also sometimes clears itself up and sometimes gets worse.
The high rpm miss is there no matter what.
Thanks again,
Dave
Old Oct 1, 2005 | 08:28 AM
Klortho's Avatar
Car: 1987 GTA
I'm still pointing toward the opti, either the cap/rotor, or the optics mainly because it's a '93 which is a non-vented unit that can get alot of moisture built up.
Old Oct 1, 2005 | 08:33 AM
Car: 88 GTA
i'm trying to get a GP going on the Dynaspark unit over at the corvette forum....you guys think anyone on here would be interested?
Old Oct 1, 2005 | 07:53 PM
Originally posted by polishdevil.Sorry if i mislead you... I can start the car up one day and it idle problem isn't there. I can start it up the next day (car is cold both days, weather is exactly the same) and it runs like ****.
I agree with Klortho then, in reference to a shot opti-spark. If you're constantly missing during high RPM, it's somewhere in you're ignition (especially with no codes being prevalent).
As for this tempermental symptom, one day good, one day bad, have you tried changing any sensors yet?
My buddy had a similar problem, only he had a 98 Grand Am, and the car would sometimes start, sometimes wouldn't.... sometimes drove excellent, sometimes stalled every other block....
No code was being thrown, but despite this, it was because of a bad sensor. My point? Don't rule out the possibility of a faulty sensor just because the SES light doesn't light up...
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
Thirim
Aug 9, 2015 06:19 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
